signal lights acting weird...
Happy New Year! I have a problem with the signal lights on my '06 zx6rr - the lights would work for a second or two and then disappear (or stop working) since the gauge's indicator goes away also as soon as it stops. If I wait for a few seconds and trythe signalsagain it comes back on - and repeats the steps... Can anyone help please thank you!
RE: signal lights acting weird...
Probably just a loose or badconnection, but as you have a newish machine, I think it should be covered be the gaurantee you got with the bike, take it back to the dealer and get him to fix it.
Si |
fo sho man, take it in before we get all into it. if they dont fix it, your going on a loose ground wire hunt. let us know what happens.
Dang both Dog and Evil are on a roll. See the above
Thanks for the reply guys. Since I have aftermarket signal lights (front/euro - back/led) you think the dealer'll void it?
Yes, unless it was installed by the dealership.
Did you install the resistors when you installed the turn signals?
Good point ^
Check your fuses as well? I know I popped a fuse cause I was being a jackass installing/testing my rear signals. Quick trip to autozone with $5 will get you a handfull.
