question???
Old Feb 25, 2007 | 04:30 AM
green636's Avatar
Default question???
can you put a zx10r motor into a zx6r 636 frame?? i have an 05 zx6r and want to swap motor for zx10r figure it is cheaper then buying a zx10r please let me know if it is possiblie or has been done thanks
Old Feb 28, 2007 | 01:15 PM
sycophuk's Avatar
Default RE: question???
yes it will fit but be prepared for a light front meaning youre front wheel will more then likley come up real easy espeacially the higher you take the rpm
Old Feb 28, 2007 | 07:15 PM
Remo's Avatar
not sure that the motor mounts will be the same for that motor, if not you will need someone that can weld aluminum and all the stuff to make sure everything is aligned right.
Old Mar 1, 2007 | 03:36 AM
Notstock's Avatar
Anything is possible but why would you want too. Not to bag on you bro but do you think you can do it better than Kawasaki?
Want a 10 go buy one. JMO
Old Mar 2, 2007 | 04:17 AM
shinobi636's Avatar
I don't see why it wouldn't fit. You may have to have new mount tabs welded in. I would definitely measure the all the engine mount dimensions on a 10 just to see where you'll be starting at, and to see how much modification you will be doing.
1stCruiser
Apr 23, 2011 03:27 AM
fastex500
Mar 28, 2008 01:41 AM
BlueDream
Nov 21, 2007 05:35 PM
