NEED HELP 02 zx7r LED SIGNALS
Old Apr 6, 2007 | 02:14 AM
brnr17's Avatar
Default NEED HELP 02 zx7r LED SIGNALS
i put an undertail on with integrated LED stop/turn signals and i put front flush mount LEDSwith 18 bulbs in each front signal. i hooked everything up correctly. now when i hit my turn signal not only do they flash fast but all 4 signals flash at the same time. what should i do?!
Old Apr 6, 2007 | 09:54 AM
markmeinteil's Avatar
Default RE: NEED HELP 02 zx7r LED SIGNALS
They flash fast because LED's have very little electrical resistance. You need either the inline resisters, or there is a module that you can hard wire into your bike. Both do the same thing. (add more resistance)
I would assume the reason both sides are flashing at the same time is because you wired the wrong leads together. Double check your wiring. If you are not sure which wires do what on your bike, use a test light to determine. And for the undertail LED's, just use jumper wires from your battery posts to test each lead.
Old Apr 6, 2007 | 10:04 AM
evil636's Avatar
Knee Dragging Pimp
hit them with a big hammer, thell slow the hell down and stop blinking
Old Apr 6, 2007 | 10:26 AM
[sm=badidea.gif]
But you will give it a mean streetfighter look! lol
Old Apr 6, 2007 | 06:30 PM
brnr17's Avatar
^^^^ i'm pretty sure i wired them in correctly ... there were 2 yellows and 2 blacks. obvious black is ground so i wired them to the black lead off the bike .. right?
Old Apr 6, 2007 | 07:45 PM
You should still test your LED's with jumpers, and use a test light on the bike's wires. Otherwise you're not going to find your problem. That's just what I'd do.
Yes, black is generally ground.
Old Apr 6, 2007 | 08:01 PM
walight01's Avatar
black isn't always the ground wire on the 7. they only way the all flash at once is if they are wired together. take a volt meter to see which wiresarethe power wires.
randomwalk101
Ninja 250R
May 25, 2013 03:00 AM
TrailCruiser
Jan 22, 2009 12:59 PM
djmgyx
Ninja ZX-7R
Aug 30, 2006 12:04 PM
my green kaw
Aug 15, 2005 06:55 AM
raychizel
Jun 27, 2005 12:27 AM
