need hair more punch
just put a one tooth drop on front sprocket little more accel but, i can eat my boys up in corners ,but off a corner i cant keep the front down ,i want to power through on a higher gear off corners .whats the best starter mod on engine w/o killing my wallet my bike 05 zx6r ninja any advise
If your on full gas off the corner and your front icomming up you need to maybe shift up faster or try the next grea up when you enter the corner.
You may be in to low a gear when entering and going through at high r's after rolling on the gas throught the corner you are almost maxed out when you gas it off the corner the front starts to rise.
I would maybe try a bmc filter and a power commander if i were you that might help you outin the corners. but it will want to make the front of the bike want to come up too. So you'll have to use the higher gear. hope that helps you out.
