-   General Tech (https://www.kawasakiforums.com/forum/general-tech-9/)
-   -   Mule 600 (https://www.kawasakiforums.com/forum/general-tech-9/mule-600-a-48863/)
nhojpalnud Nov 2, 2022 10:19 PM
Mule 600
I got a little problem that I'm sure is not new but just new to me. On my Mule 600 I replaced fuel lin, filter, pump(staying w/stock) however after I start it up and let it idle I use up all the fuel in the filter and the carburetor bowl and she dies. Not to restart. I'm wondering about that flat little fuel pump...Does it have enough "stuff" to pull the fuel from the tank to keep the carb fed. Seems I use up all the fuel in the filter and have to crank it a while to get it going again only to starve out when filter runs dry, On a small block chevy or Dodge I would just install an electric pump and that would handle the problem On this thing, elec pump is too much PSI for carb to handle. Where do I start?
