-   General Tech (https://www.kawasakiforums.com/forum/general-tech-9/)
-   -   Misfire after installing a new battery (https://www.kawasakiforums.com/forum/general-tech-9/misfire-after-installing-new-battery-46130/)
cfuller 11-25-2018 04:12 PM
I have a 2013 Valcan 1700 .Just put in a new battery. went for a test ride and started to misfire under a load ..Came home and checked all connections they were tight. Seems to have dropped a cylinder.Anyone ran into this any help would be gratly appreciated .Thanks
kawmanzx14 11-26-2018 12:54 AM
The simple thing to do first would be to pull and look at spark plugs, Just changing a battery won't cause a misfire,
Rob9876 11-26-2018 03:20 AM
You may want to try the Vulcan forum here: Kawasaki Vulcan Forum : Vulcan Forums
Dragone#19 12-08-2018 10:20 PM
Plus one. Have you checked the coil/s I do not have the factory manual in front of me to look at.
rgman 01-18-2019 05:32 PM
+1 It's probably a coincidence. Check the ignition system, spark plugs first!
