Leaking Speedo Cable
Old Jul 28, 2008 | 10:58 PM
joemeltn1's Avatar
Default Leaking Speedo Cable
I have a 1987 454 LTD - still in great shape and pretty much all original as I bought it. Today it started leaking oil from the speedometer - seems to be at the connection or up inside of the speedo housing - hard to tell. Is there a seal that can be replaced or might it be a plugged crankcase vent? I've inspected the cable sheath for cracks or dry rot and don't see any Any suggestions will be appreciated.
Old Jul 29, 2008 | 01:20 AM
whitehendrix's Avatar
where exactly is it leaking? all the way up at the speedo, or down where it connects at? may just be a simple seal replacement at the drive end and you're golden.. might be able to get the seal at an industrial supply place.. i get mine for about 1/4 of what they cost, as well as bearings and other stuff from an industrial supply house..
welcome to KF!!!!
Old Jul 29, 2008 | 11:45 AM
joemeltn1's Avatar
Default I goofed - leaking tach cable
Hey thanks for the response!! Is the seal like an O-ring?? the leak seems to be either at the connection or up inside the tach housing.
CousinLarry
May 11, 2010 12:24 AM
lcpl0331
Aug 12, 2008 02:10 AM
joemeltn1
Aug 8, 2008 08:10 PM
Blackhawk2k7
Ninja 500R
Nov 3, 2007 07:16 AM
eclipsehunter2001
Oct 26, 2006 12:24 AM
