Kx80 1998 need help
Hi I just got a 98 kx80 and its almost complete but I need a carb and I'm not sure where I can buy the whole part if you guys have a good parts supplier that would have it that would be great!
Thanks!
Thanks!
Where have all of the wrecking yards gone! I love those things.
Here is a link on a new oem carb. You should check around as you are I am sure to help you make the decision. Kawasaki Motorcycle Parts 1998 KX80-W1 KX80 CARBURETOR Diagram
I found some carbs but i need to know what bore size I need, what does the bore size measure on the carb? All I have on my bike is the slide. Is there anyway I can measure the slide and intakes on engine and filter side then just find a carb that matches up?
dbblo
Dec 17, 2005 07:32 PM
