KLX idles up by itself when hot
Old Apr 19, 2021 | 09:08 AM
Alan's Avatar
Default KLX idles up by itself when hot
Hey guys.
my 2017 KLX 250s revs up by itself to about 4-5k rpms when the engine is hot when I pull the clutch in or neutral. Re built the carb with stock parts about 5 months ago (3k kilometres). It’s so annoying. I have read about vacuum leaks, some people say carb tuning. Anyone found they had the same problem?
I did the clutch plates 5 months ago aswell, not sure if one of that has anything to do with it either .
cheers
Old Apr 20, 2021 | 12:40 PM
Grunty's Avatar
You have a lean idle circuit condition going on here.
That can be caused by a vacuum leak at the carb manifold boots and/or a lean jetting/carburetor adjustment issue.
What have you done with the bike since it was running normally? Start there.
Old Apr 20, 2021 | 04:02 PM
tooter's Avatar
That's called the "Last Touched Rule".
What was touched last?
Old Apr 22, 2021 | 09:47 PM
^what Grunty said
charlemagne
KLX300R
Aug 14, 2017 01:09 AM
Lowrider1963
Feb 17, 2014 03:06 PM
Greenmenace
Sep 30, 2013 02:26 PM
jamesc
May 14, 2009 01:47 AM
chickenstrip
Feb 13, 2008 10:34 PM
