Kawasaki KZ1000 Plug Fouling
I've got a 1981 KZ1000, it's got about 9800 original miles on it. I had been sitting for about 8 years before I started to ride it. I've been riding it in town to get back and forth from class (about 3 miles each way).
My #1 cylinder keeps fouling out at about 50-75 miles of riding. I changed to hotter plugs and still haven't seen much of an improvement. When I take the plugs out the #1 cylinder is always wet and jet black as if it hasn't been combusting for a while. All the other cylinders seem to be fine. Any suggestions? |
RE: Kawasaki KZ1000 Plug Fouling
Does it have screw on plug caps some times moisture gets in and the wire corrodes and gets loose if you have long enough wire on#1 cut it back about half inch and srew cap back on make sure its not loose at the coil tohttps://www.kawasakiforums.com/micons/m15.gif
I am thinking that you use the stock plugs and do a rebuild/cleaning on the carbs. Especially since it is only on one cylinder. But the "faulty" plug wire makes sense also.
Hrm yea I was hoping it wouldn't come down to that, it's got those coil packs so if I gotta change a wire then I gotta change 2 plus one of the coil. I haven't taken the time to rebuild the carbs yet, I was hoping not to have to pull them out again :( Do you think it could possibly be a carburetor adjustment? Possibly one carb is running too rich?
My speculation of a carb not sealing at the moment. But is usually cheaper to check than to replace coil and wire.
