i want to get rid of old handle bar grips....help
i recently got a 02 zx6 , changing almost everything but the old handlebar grips are really stuck on any help on making the removal any easier?
RE: i want to get rid of old handle bar grips....help
Cut them off. Maybe try to blow some compressed air between the grip and bar to break them lose.
You could also try soaking each end with some penetrating oil overnight i've had some luck with that in the past.
Good luck :D |
test.....
Cut it, clean it and insert the new one. |
wd40
check check test test test 1 test 2 chiggy check microphone check 1 chiggy check microphone test 2
wd40 did the trick ...Thanx
sweet. i win
i've always just cut old ones off my kx. fast and easy. less getting pissed off.
