help i need to go riding
Old Apr 15, 2009 | 10:46 PM
jeffzx9's Avatar
Again, I'm not an expert on the newer stuff, but you might want to look at the water pump gear drive shaft seal. If the pump shaft gets cocked (slightly) you can lose oil around it where it goes into the engine. If you"re getting oil from that area, you probably want to pull the cover again anyway, just to make sure it's not contaminating the coolant. The only other areas (looking at my old bike) that could possibly leak would be the gear shift shaft or the final drive sprocket (behind the water pump cover on my bike.) My bet would be the pump drive shaft seal. If you're so inclined, post some pics of what you are looking at (before you take it apart again) and maybe we can narrow/better define the problem. This is part of bike ownership. These (there will be more) repairs will add to your understanding and (yes) appreciation of how bikes work. Corny, but true.
Old Apr 17, 2009 | 12:35 AM
Originally Posted by krakr
i apoligize its getting frustrateing to figure it out. it is from the gear drive/ water pump mating surface. oil is coming from that area. No i did not use a gasket sealant, are you suppose to and if you are what kind................sorry if i got you confused.
Without looking at a manual, most metal to metal surfaces need a seal.
ulvanp
Sep 4, 2008 05:25 PM
toad1025
Jun 29, 2008 01:34 AM
mikess06
ZZR 600
May 14, 2008 03:16 PM
BlackNinjaZX6R
Jul 16, 2007 04:09 AM
shon
Mar 30, 2006 09:05 PM
