help i need to go riding
Old Apr 13, 2009 | 07:27 PM
krakr's Avatar
Default help i need to go riding
I have a 2005 636 the fuel pump had a leak so i took it apart and put new seals on. I got it all back together and started the bike. A few seconds later oil started to poor out the bottom of the bike. I put everything back on the way it was suppose to go on i just wanna know what can i do to fix this problem. Please help me i am feenin.............
Old Apr 13, 2009 | 09:01 PM
jeffzx9's Avatar
If you just changed your oil, put the drain plug back in.
Re-trace your seal procedure; are you sure everything went back exactly as it came out? No extra parts remaining?
Old Apr 13, 2009 | 10:57 PM
Bummer, but you'll figure it out with the help of these guys on the forums. Oh and welcome to the forums by the way.
Old Apr 14, 2009 | 12:44 AM
krakr's Avatar
havent changed oil yet and i am positive that everything went back as it came out....... and thanks for the welcome deej.........
Old Apr 14, 2009 | 01:55 PM
welcome to KF. where is it leaking from??
Old Apr 14, 2009 | 06:31 PM
krakr's Avatar
TY, the water pump. it wasnt leaking oil before i changed the pump just coolant...........
Old Apr 15, 2009 | 09:18 AM
I am confused.....
Then this? or is this a new problem?
Old Apr 15, 2009 | 06:30 PM
krakr's Avatar
the water pump was leaking coolant at first. i changed the seals for the water pump. after i put it back together, i started the bike up and a few seconds later the bike was pooring out oil from the water pump. why is it pooring out oil from the water pump, i dont know, trying to find help to fix this problem.............
Old Apr 15, 2009 | 09:00 PM
jeffzx9's Avatar
krak, we need to be sure we understand. First you said the fuel pump, then you said the water pump. I'm no expert on the newer bikes, but it sounds like you have a serious seal problem somewhere in the gear drive/water pump mating surfaces. The oil is leaking from or around the area you just repaired, correct? (Not coming from some other place; bottom of case, etc.?) Did you use/not use a gasket sealant or new gasket or something? We're missing a critical detail here.
Old Apr 15, 2009 | 09:15 PM
krakr's Avatar
i apoligize its getting frustrateing to figure it out. it is from the gear drive/ water pump mating surface. oil is coming from that area. No i did not use a gasket sealant, are you suppose to and if you are what kind................sorry if i got you confused.
