Gpx 750
Gpx 750
I'm working on 1990 GPX750. It was kept outside in three years covered by a blue sheet. After I clean its carburetor, it starts and run good but the engine sometimes stop when it's idle. Then it starts right after. The engine doesn't stop very often but it happens when the engine is warmed up.
I checked wiring if there are any corrosion. The TIP sensor on the fuel tank seems working okay.
Please give me any advice if anyone know the idea where I should check for the problem.
Thank you.
Thank you.
harrylarrylofer
09-10-2009 06:02 PM
