-   General Tech (https://www.kawasakiforums.com/forum/general-tech-9/)
-   -   fuel pump (https://www.kawasakiforums.com/forum/general-tech-9/fuel-pump-13934/)
smokey Jul 19, 2007 03:14 AM
fuel pump
how do you test a fuel pump 93 zx 6
mmi86 Jul 19, 2007 03:32 AM
RE: fuel pump
i could be mistaken isnt the 93 carb? hey i might be wrong
Dragone#19 Jul 19, 2007 05:38 AM
RE: fuel pump
Even my '90 zx7 has a fuel pump mmi86.
Put a gauge on it and test the pressure smokey.
mmi86 Jul 19, 2007 12:32 PM
RE: fuel pump
Zx600-d4, zx600-e1,and the zx600-c6, all are carbureted , thats all of the 1993 models
Kohburn Jul 19, 2007 01:31 PM
RE: fuel pump
most carburatos that i've run into other than garden tools still need a fuel pump and want anywhere from 3-8psi (atleast from my autoomotive experience)
my 95 zx6r is carbed and has a fuel pump.
Kohburn Jul 19, 2007 01:34 PM
RE: fuel pump
ORIGINAL: Dragone#19
bingo
when pumps start to go bad they will still flow gas if disconnected btu when connected can't maintain pressure at higher flow rates required (start starving the motor at higher rpm)
mmi86 Jul 19, 2007 02:17 PM
RE: fuel pump
ok im on k-dealer.com as we speak, looking at all the 93 models no fuel pump in the tank, ie, where else would kawi hid the little fellow, olny thing isa fuel separator which is not the same thing as a fuel pump it stillwork off of vaccum
mmi86 Jul 19, 2007 09:36 PM
RE: fuel pump
I'm sorry for the confussion, the only one that didn't have a fuel pump was theZx 600r. Both of the zx6 and zx6r had fuel pumps.
smokey Jul 19, 2007 10:13 PM
RE: fuel pump
what kind of gauge would they no at the auto parts store
Dragone#19 Jul 20, 2007 12:40 AM
RE: fuel pump
Just a standard fuel pressure gauge really depending on the pressure involved. You may need to McGyver it so that the fitting will fit the hose.
