Front directional lights and instrumentation lights go on after ignition turned off
Bike: 2001 ZG1000A16
To Fellow Riders: Does my J-box need rebuild or is there a hot wire? Could the following problem be a J-box rebuild or is my problem a wire becoming energized on its own. Heres the scenario... Front directional lights and instrumentation lights go on after ignition turned off. This is an intermittent problem that only seems to occur after bike is very warm/hot after a long ride. When the lights do comeback on, it happens about 5 to 10 minutes after bike is switched off. when the lights come on on their own, the lights will go off when the ignition is switched On then Off. Already had to buy a new battery last week when the lights came on and i forgot to check them so they drained the battery beyond it being able to take a charge. The ignition switch was replaced and problem still exists. I think there is a wire intermittently being energized. There is only a small amount of wires exposed so before i start to tear open the wiring harnesses, does anyone have any suggestion? In advance, Thank You ~ David |
