Engine Dies when shifting... [SOLVED]
Hello everyone,
I just bought a 1997 zx-6r. I test drove it and it felt great!!! (definitely didn't have this problem) and then when I go to start it up the next day I can get it running in neutral but when I pull the clutch and change gears the engine dies. The engine runs great otherwises A related problem may be that if I try to start the engine SOMETIMES in neutral, the bike just clicks really fast and demands that I pull the clutch, start it and then I can let it go. I can't start it with the clutch in on any other gear either. PLEASE HELP - I'm so scared [:o] |
RE: Engine Dies when shifting...
Sounds like maybe the neutral sensor is not working. I am not to sure about yours but on my 95 zx7 there is a wire that comes from under the seat compartment and attaches on the left side of the transmission near your shifter. Check and make sure it is making a good connection.
Also about stalling when putting into gear make sure your side stand is up. If it is down the engine will kill it self. Hope this helps. |
You got it!!!!!!
Hehe...I can't believe I forgot about the kickstand!!!!! Ahwww I feel so good!! I'm going to start a new thread for my click problem.... Thank you so much NotStock..your the best! Justin |
No problem bro.
On the clicking make shure your not in gear either and you are starting in neutral. Check the neutral sensor wire as well. These are all problems I have had before. Except for the side stand of course:D |
I got my first bike about a week ago. I had the same problem. Except I solved it when I looked down at the shifter and saw the kick stand still down ;)
| All times are GMT. The time now is 03:16 PM. |
