Brakes?
i have a 2007 eliminator and my rear brakes started squeaking too - they now decide to squeak all the time!! lol
check for dirt/dust and excess moisure - first time round mine just needed a good clean
onle thing that also helped me was doing a bit of excessive braking
find youself a car park or empty road and ride along at fairly slow speed, then give the back breaks some excessive heavy braking - don't brake for too long - literally on and off - and obviously try not to brake so as to lock the rear wheel - but it helped to shake off some loose dirt and the squeaking did stop
but in my experience a bit of squeaking was nothing to worry about - it doesn't mean anythings seriously wrong
if you're in a lot of doubt or its really loud and worrying take it to a dealer and talk to them about it.
Your bike's been standing around a lot.
Try a few hard applications of the brake. If that has no effect, remove the pads, clean out any crud around the caliper piston, check the caliper mount and that the caliper is free to slide or pivot, and put a dab of copper grease on the back of the pads before you replace them.
Rob
Rob
Something to check:::
On smaller cruisers, you will (without realizing) apply slight pressure to the rear brake from your toe touching the pedal. That causes your brake shoes to heat up, causing the squeak.
Try moving the adjuster nut out a few turns, to allow more movement in the pedal. 2 or 3 full turns outward (counter clockwise) should increase the force needed to apply the brake, hence, slight pedal touch won't apply the brake.
I give that a try. I think I saw that adjuster nut you talking about when I was changing the oil, I'm learning. I did sign up for motorcycle repair course though. I'm hoping to save me some headache in the future.
Rob
Rob
as the bike has a rear drum brake how do you get to the brake pads in order to clean it all out inside - i had a brief look today while changing the front brake fluid, but couldn't quickly see an obvious way of doing this.
would you have to take the rear wheel off to get to it?
the squeaking for me now won't stop after harsh braking like it used to and as my bike shop is crud they've probly never changed the brake pads so have never opened it up - might as well save me some money and have a look myself - plus i'd like to be able to have a look - another thing to add to the list of things i can do myself
