90 zx11 starter wiring question
2 Attachment(s)
I got a 90 zx11 with a previously hacked harness. The plug that goes onto the starter solenoid/relay was already broken so he crimped on female connecters and figured it out. When I got it they were unplugged and can't get anything too work no matter how I plug them in. I'm looking for a pic maybe of which wire wire goes to which spade. Just too verify and then can go from there. Maybe the relay is junk or other bad wiring but look at the pic of mine and see what you think. When cables are hooked up I have power too both top spades but nothing too the two under them.
hmm, your factory manual is worth its weight in gold info. Welcome to KF
I have the manual but it shows the pins inline so I'm still just guessing. If you look at the pic of the relay its power too the cables. Nothing on the 2 pins right above and the top two are live all the time but since nothing works that I've tried I still want to verify and maybe try a cheap relay and see if theres more wrong than I know.
Heres a few more pics. I'm leaning toward drag bike cause of the lack of everything but we will see.
3 Attachment(s)
Ok I think this will work now.
Originally Posted by bnokle
(Post 537575)
You have the factory manual? If so, I will dig out mine and we can compare notes. Just that tonight, I need to catch up with the forum for just abit. Sorry brotha for the delay edit: The factory wiring harness is pretty straight forward with the factory manual. |
