84 kawasaki voyager senser problems
my oil senser light comes on and off for no apparent reason. Check oil and oil level buts all that is good. Please help
Welcome to Kawasaki Forums.
Hang-in there, alot of good members here. someone should be able to help soon.:D |
It's sensor.
If the oil level and pressure is good then the problem is either a faulty sensor or perhaps a bad earth to the sensor or some other electronic fault. |
Originally Posted by MaverickAus
(Post 409323)
It's sensor.
If the oil level and pressure is good then the problem is either a faulty sensor or perhaps a bad earth to the sensor or some other electronic fault. true, but I would probably change out the oil filter depending on what mileage you have listed first. ( you omitted this info) |
Oil Senser Light on 84 Kawasaki Voyager
Ty for your help... I did change out the Oil& Filter and it still has same problem. Light will be on when i start it and drive then somtimes it will not come on when started. Where will i find the senser so i could check it or replace it.. again ty for your help
As Mav mentioned, how was the oil pressure test? Have you verified the sensor being good? Best of luck.
Again it is spelled sensOr not senser. Sorry I don't know the specifics of your bike, do you have a manual?
| All times are GMT. The time now is 06:38 AM. |
