2nd gear wont work on my 97 zx600
Old Jan 5, 2010 | 03:46 AM
97zx6timmy's Avatar
Default 2nd gear wont work on my 97 zx600
I shift into 2nd and it pops back into neutral, so it doesnt work at all. I was just wondering, if i tottally skipped 2nd and rode the bike as is, will it damage the bike worse and eventually mess the bike up ? also if i pay a kawi mechanic to fix the problem what will The cost be? thanks in advance for the help- Timmy
Old Jan 5, 2010 | 11:32 AM
wiffthedv8's Avatar
it can be dangerous and could damage bike more. if u use kwak shop they rape u but most good bike shops fix for 150 to 200 pounds .
Old Jan 5, 2010 | 11:33 AM
95451's Avatar
Welcome To Kawasaki Forums.
They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there.
Old Jan 5, 2010 | 04:51 PM
97zx6timmy's Avatar
so dont ride the bike with 2nd gear f'd up? i was gonna try to ride it untill i got the funds to fix it. if its gonna screw it up worse than i wont.
Old Jan 5, 2010 | 05:11 PM
768 Ryda's Avatar
sound like your shift forks are bad, if you decide to do the work yourself or take it to a shop i would suggest replaceing 2nd & 5th gear because they are right beside each other and replace both 2nd & 5th gear shift forks aswell
Old Jan 5, 2010 | 05:15 PM
97zx6timmy's Avatar
im gonna have a mechanic do it, but my main question is, Can i ride it as is or will my bike be totattly ****ed eventually?
Old Jan 6, 2010 | 04:32 AM
I would not personnally. You are just causing more wear and tear on an other words good ride. Plus who knows what will happen to the rider if something locks up? If you can, take care of business now and then enjoy the full benefits of your ride.
Old Jan 6, 2010 | 04:37 AM
Odimus's Avatar
park it and get it fixed...unless you don't mind spending more money to get it fixed...
Old Jan 6, 2010 | 04:52 AM
97zx6timmy's Avatar
what do u guys think they will charge me for parts/labor , to Replace 2nd and fifth gear and whatever needs to be replaced in order to fix 2nd gear? I just need a good estimate so i dont get ripped off. Thanks for the advice guys!
Old Jan 6, 2010 | 05:01 AM
splitting the cases is not a 2 hr job.
edit: take a peek at what your manual is describing on the tear down and on the install. The extra gaskets, measuring time is not listed in there either. I am looking in my 98 manual, so yes, things could be different, but I doubt it if it is the same engine.
