-   General Tech (https://www.kawasakiforums.com/forum/general-tech-9/)
-   -   1995 KX250 Engine Casings (https://www.kawasakiforums.com/forum/general-tech-9/1995-kx250-engine-casings-37490/)
jontymiller Mar 21, 2012 10:05 AM
Hey
Does anyone know if the Crankcases on a 1994 or 1996 will fit a 1995 gears,etc. Kawasaki no longer make engine cases for a 1995
PLease help
Jonty Miller
New Zealand
Dragone#19 Mar 21, 2012 03:46 PM
wow, I thought you were kidding.
Checked the fiches. Looks like the 94 may be your closest match to the 95. 94=14001-5335, 95=14001-5336 while the 96 was way different.
You may need to contact kawi themselves to answer your question.
edit: Bike Bandit has them it appears. http://www.bikebandit.com/houseofmot...m3839#sch73295
jontymiller Mar 21, 2012 08:50 PM
Yeah its A pain. I looked at the fiches they all look exactly the same except for the part numbers! Im so confused!
BleednGreen68 Mar 24, 2012 08:11 PM
Well if the part numbers are diff then there is obviously some weird difference but it could be cause they added some extra mounting point on the outside of the casings.
