1981 Z200 Front Brake
Old Apr 12, 2008 | 12:38 PM
bennymeboy's Avatar
Default 1981 Z200 Front Brake
I have just been given an old (but perfectly useable) Z200.
Great fun apart from the awful cable operated front brake.
Does anyone know if there is a hydrolic front brake that will fit straight into the place of the stock unit. or is there any way of making the exisiting brake work better.
Thanks in advance for any advise
Old Apr 13, 2008 | 05:51 AM
whitehendrix's Avatar
Default RE: 1981 Z200 Front Brake
well.. first off, welcome to KF!!
secondly, how corroded and kinked/worn is the steel liner in the cable? or the cable itself.. if you've lubed up the cable but have not has sucess in freeing it up more, a new cable may be a wise choice to buy some time til you can (possibly) convert to a hydraulic setup.
i'm sure theres a way.. it's not drum tho, is it?.. not too familiar with it, and am too lazy to look it up, like i should do..lol
Old Apr 13, 2008 | 05:52 PM
bennymeboy's Avatar
Thanks for the welcome.
It is a cable operated disc brake, the cable is relatively new, but i will pull it apart and give it a good oiling. I used to have one of these types of brakeon my old Honda 125s (My My My the memories come flooding back, 1976 I think)and that was useless too. I have a new set of pads to fit but won't attempt that until i can locate a Haynes workshop manual on ebay.
Old Apr 13, 2008 | 09:00 PM
cable operated? Pic of an 80 and 81 show a resevoir for the front brake.
Old Apr 13, 2008 | 11:37 PM
bennymeboy's Avatar
No reservoir, and definatly a cable. so where can i get hold of one of those hydraulic ones, the fork leg fitting looks the same.
Old Apr 14, 2008 | 01:17 AM
good question. Maybe theeuroperiders have it easy and hydraulic comes standard! Not sure. Would think that it would be an easy enough swap though.
rich 122
Classic Sportbikes
Feb 5, 2009 01:54 PM
Sid Post
Apr 22, 2008 04:26 PM
81csr
Classic Touring Bikes
May 16, 2007 02:53 PM
Hoss
Classic Sportbikes
Apr 1, 2007 07:14 AM
kustompup93
Classic Sportbikes
Jan 11, 2007 07:17 AM
