05' KX250f spark problem
I have a 2005 kx 250f that i have replaced every piece of electrical on the dang thing and still has no spark at all. ive tested all of the wires and everything and still nothing. Can anyone help?
Thank you
Ryan Schultes GNCC #636
Thank you
Have you checked this list?
No spark; spark weak:
Spark plug dirty, broken, or gap maladjusted
Stick coil not in good contact
Spark plug incorrect heat value
Faulty CDI unit
Crankshaft sensor trouble
Stick coil trouble
Engine stop switch shorted
Neutral switch trouble.
Wiring shorted or open
Flywheel magneto damageStick coil not in good contact
Faulty CDI unit
Stick coil trouble
Coil might be bad, I would check that before you do anything.
