-   General Tech (https://www.kawasakiforums.com/forum/general-tech-9/)
-   -   03 zx12 spitting and sputtering (https://www.kawasakiforums.com/forum/general-tech-9/03-zx12-spitting-sputtering-32168/)
badassdavis4ever Apr 13, 2010 04:36 PM
Hello, I am having a problem with my ninja. I have an 03 zx12. Bike was running normal and then one suddenly one day its not. Heres the problem... If i go in any gear above 5000 RPM it starts to spit and sputter and almost die out (almost as if running off of 2 cylinders.) The bike starts fine, and idles normal. It runs basically normal until 5000 Rpm, then i lose all power and cant do over approximately 75. Or if I am below 5000 if i give it more then 1/2 throttle it will do the same thing. I dont understand how this just happened all of a sudden. Bike has never done this before other then when i needed to replace the voltage regulator and some other part, i dont believe it is this again, because it isnt acting quiet the same. I also run a power commander 3 on the bike, if this makes any difference. With a full muzzy exhaust. ANY HELP OR COMMENTS WILL BE GREATLY APPRECIATED. THANK YOU EVERYONE
Prom Apr 14, 2010 02:07 AM
Sounds like a fuel problem to me, could be bad gas, low fuel pressure dirty carbs etc. I'd start with a carb cleaning and go from there. Since its happening at high revs and high throttle settings I would guess that its not supplying enough fuel or putting in too much, either way thats my guess. If it was a problem with the ignition system it shouldnt matter what the throttle setting is. Let us know how it goes and welcome to KF!
hoedogg Apr 14, 2010 03:01 AM
dirty carbs sounds right. welcome to KF
Prom Apr 14, 2010 04:37 AM
Then again my jets fell out once and it did the same thing, but that was a one in a million...
Dragone#19 Apr 14, 2010 07:18 AM
hahahaha, only on your ride Prom. But yes, fuel related issues would be my guess as well.
Prom Apr 15, 2010 01:28 AM
Trying to say something Drag? I'm listening ;)
