help 05 636
i have a 05 636 i just bought it its my 2nd bike and wanted to do a couple mods to it exhaust being the first. ok so here is my prob i bought a jardine rt one exhaust and when i went to install it the factory exhaust has the exhaust valve servo and the jardine doesnt how will this effect the bike and what can i do?
Do a search in KF since that has been discussed. Enjoy the ride and welcome to KF.
Hmmm, I'm probably giving you false info but you may be ok, I havent looked into it.
+1 on the search drag, it is a popular discussion. Welcome to KF! |
I have the same problem as well on my 05, that really isnt a problem its an electronic clicking noise under the seat when the key is turned before start up, Dealer said its no problem. Said it was because of my devil exhaust.
Your bike will work with out one, but your (FI) light will go on. you can buy a EFI Servo Limiter from Muzzy or off of 58cycle to prevent that. I have a two-bros exaust with a EFI Servo Limiter on my bike and it works fine.
help 05 636
I just got my first turntable used for the sole purpose of playback only. Its a Numark TT100. I bought a new needle for it as well. But, when I hook the audio up the left side is extremely low and the right side doesnt work at all. Is there anything I can do to correct this problem?
same day cash advance | pay day loans |
Originally Posted by speedjunky636
(Post 414034)
Out of couriosity, does the servo limiter do the same thing as the "power valve"?
Followup, can it also use the jumper mod? |
not sure...the 05 can use the jumper mod...
Right but the jumper mod effects the stock servo was wondering if the muzzy one worked the same way
| All times are GMT. The time now is 10:30 AM. |
