frame slider install
Old Feb 5, 2006 | 09:10 AM
Fever's Avatar
Default frame slider install
I have an 05 636 and have been debating between cut or not cut. Any feedback would be great. Also how to. I was reading the service manual and it talks about tightning the engine mounts in the order. If I'm just taking out the top bolts then for the sliders then can I just put them back in? Any help would be appreciated.
Old Feb 5, 2006 | 10:03 AM
arrowwhead's Avatar
Default RE: frame slider install
Read this thread to give you a background on some frame sliders. https://www.kawasakiforums.com/m_195..._/tm.htm#20065
Then read this thread on how to install a "no cut" frame slider if you decide on that one. https://www.kawasakiforums.com/m_161..._/tm.htm#16120
I learned the hard way. Don't make the same mistake I did.
Let us know if you need any more help dude.
Old Feb 5, 2006 | 08:49 PM
Fever's Avatar
hey arrowwhead thanx alot. I'll check them out.
Old Feb 5, 2006 | 08:55 PM
Fever's Avatar
Ok I read those threads but non addressed weather or not i had to tighten the bolts in any specific order. Do I. Did you go with the no cut. If so why?
Old Feb 8, 2006 | 05:25 PM
motogprocks's Avatar
i dont mean to sound like im hacking on you...because im not.
there just frame sliders.. dont be affraid of them
Old Mar 10, 2006 | 07:08 AM
joboy77's Avatar
I put Vortex sliders on my 05 no problem. I didn't tighten the bolts in any order. Just one side at a time. Oh and if you have a dremel or similar tool, cutting the fairing on the left side is no problem. Just go slow.
Old Mar 10, 2006 | 08:29 AM
evil636's Avatar
Knee Dragging Pimp
ORIGINAL: Fever
ok man, imo, i would go with the cut ones because they are a straight bolt on, the ones that have a bracket that moves the contact point out is going to bend the bracket, possibly shove the slider into the plastic. solid mount sliders will bend too, they are not indestructable but they have less of a chance of failure then ones bolted to a bracket.
look up the torque specs on the motor mounts, do one side at a time, retorque to factory specs and your good to go.
if your anywhere in so cal and dont mind riding down to long beach swing by one sunday, ill help you out. hopefully ill have my sliders in a week or so.
Old Mar 15, 2006 | 04:53 AM
frrogger1's Avatar
hey i would recomend going with the cut ones i just put some no cut on my bike the other day and then dumped it yesterday and well here are some pics of the no cut slider pic 1 pic 2 pic 3 pic 4 pic 5
Old Mar 15, 2006 | 06:10 AM
evil636's Avatar
Knee Dragging Pimp
sorry you had to be an example for exactly what i was saying in my above post frogger. did you get a list of things you need yet ?
Old Mar 15, 2006 | 07:11 AM
xmxracer's Avatar
UNFORTUNATELY I GOT THE NOT CUT DELRIN OR DERLIN OR WHAT EVER THEY ARE. LUCKILY I HAVEN'T TO TEST THEM OUT, BUT THEY LOOK TO SHORT TO DO ANY GOOD. MINE WHERE ALL ONE PIECE DERLIN (HARD PLASTIC) THEY DON'T HAVE THE ALUMINUM MOUNTING BRACKETS. STILL THINK THAT THIS WAS MY WORST AFTERMARKET PURCHASE. $75.00 FOR SOMETHING I DON'T THINK WILL WORK.
