2012 Kawasaki Ninja 250 - Overheat Light
Hey Guys,
This bike got over 1,700 miles, when I first got it I noticed the temp light went off whenever I warm up the bike or drive at low speeds in the city with too much traffic, but today something different has happened since the weather is now in the 70s, I start hearing water boiling, steam came out then coolant water started leaking from the tube at the bottom of the bike, I've been told this shouldn't happen. Coolant level is perfect, but I never heard the fan working period!!! at first I thought temp light on is normal when I'm in the city ( I'm a new rider) but after reading owner's manual I noticed this shouldn't happen unless there is something wrong, please let me know what do you think?
There is definitely something wrong.
Check the fan and switch. The temperature switch will screw into the radiator somewhere. Bridge it with a piece of wire to see if the rest of the circuit works. If the fan comes on, you probably need a new thermo-switch. If not then you'll need to test the fan directly.
I took it to the dealer and guess what:
1. Due to the leakage the reservoir was empty and radiator was very low in coolant .
2. Fan fuse was popped out , warmer weather has made this issue more noticeable water boiling, steam, and leakage (overflow). The thing I'm trying to understand is why the fuse popped out????
3. Fan works fine .
3. Fan works fine .
