front brake discs too close to right fork?
as the title says while I was replacing my front tire after changing a flat to it seems that the disc of the front brakes is rubbing his right front fork and I am unable to turn the wheel because of it.anyone have any ideas what I might be doing incorrectly? The speedometer cable on the left is mounted correctly by the way
***UPDATE***
Well it seems my first instinct was correct.Even though I thought I had done due diligence in making sure not to misplace anything it turns out I had dropped the collar #92143 that goes on the axle right side.After installing this (after cleaning the mud from the yard off...)the wheel of course spins correctly.
Lesson-Double Triple check your parts when disassembling them.
Thanks for everyone's time
DD
