front brake discs too close to right fork?
Old Feb 14, 2015 | 12:42 PM
DarkDarwin's Avatar
Default front brake discs too close to right fork?
as the title says while I was replacing my front tire after changing a flat to it seems that the disc of the front brakes is rubbing his right front fork and I am unable to turn the wheel because of it.anyone have any ideas what I might be doing incorrectly? The speedometer cable on the left is mounted correctly by the way
Old Feb 14, 2015 | 01:30 PM
DarkDarwin's Avatar
Also,there is but one washer involved,I'm fairly certain it goes on the left side with the cotter pinned nut.My first thought was that I had lost something like a washer that would provide spacing for the brake disk (or the six nuts on it ) clearance from the right fork to turn freely.However I'm sure I haven't lost any pieces, as I'm not the most mechanical person ever I paid extra close attention while I was removing the wheel to not misplace any parts.
***UPDATE***
Well it seems my first instinct was correct.Even though I thought I had done due diligence in making sure not to misplace anything it turns out I had dropped the collar #92143 that goes on the axle right side.After installing this (after cleaning the mud from the yard off...)the wheel of course spins correctly.
Lesson-Double Triple check your parts when disassembling them.
Thanks for everyone's time
DD
Old Feb 14, 2015 | 04:33 PM
Glad you figured it out, I was gong to say a spacer dropped out.
oldskooldubbin
Apr 7, 2010 02:15 PM
rajdeep
Apr 19, 2009 07:14 PM
kx slaughter king
Jul 27, 2008 01:39 PM
Tolikelis
Jan 25, 2008 07:08 AM
firstninjabike
Joke section!
Feb 3, 2007 07:25 AM
