DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Starting bike after it sat for years
Old Aug 18, 2020 | 03:54 PM
Ndigo750's Avatar
Default Starting bike after it sat for years
I have a 1981 Kawasaki KZ750H LTD. It hasn't been started for years. What type of maintenance should I perform before starting it?
Old Aug 18, 2020 | 08:45 PM
Odds are the carbs have had the gas in them dry out leaving a residue that will come off when wetted with fresh gas, then proceed to clog up the pilot circuit making it so the bike will only run on choke. Really the bowls will need cleaned out before starting - or take a chance and go for it.
Old Aug 18, 2020 | 10:46 PM
Ndigo750's Avatar
Thanks. Should I do anything else to the carbs?
Old Aug 19, 2020 | 08:42 PM
If by some chance you can get the float bowls off without removing the carbs, make sure the floats move and the float needles appear to be moving and seating, clean the bowls, put them back on and try it out.
Otherwise it's a carbs off to do the work.
Old Aug 19, 2020 | 10:10 PM
Ndigo750's Avatar
Thanks for the tip.
timc63
Sep 10, 2015 06:39 PM
Insbroker2
Jan 15, 2014 05:06 AM
Biff-a-nator
Apr 15, 2011 10:32 PM
alexanderholuka
Jul 13, 2010 11:29 PM
bobby1950
Feb 25, 2009 04:29 AM
