DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Vulcan classic 1500 carburetor adjustment
Old 05-18-2017, 02:55 AM
mdobias1118's Avatar
Default Vulcan classic 1500 carburetor adjustment
I have a 97 vulcan classic 1500D that I bought 2 months ago. At the time, it didn't have a spark and was only firing on one cylinder before that (apparently). I replaced both ignition coils, spark plugs, wires, battery, voltage regulator, cleaned out gas tank and fuel lines, entirely cleaned carburetor. I replaced the main jet to a 132, due to V&H recommendation for using their straight shots. When starting it, the carb is coughing. Once I roll on the throttle a couple times and fire it, usually it starts. Once I warm it up, it will idle beautifully. Once I get it on the road and open it up, it will backfire and stutter when I accelerate. I've gone through all main jet sizes from 132 to a 140, no difference. I've adjusted the pilot screw from 1/4 turn out, to 7 full turns. No change. Everything is clean inside the carb, too. I'm at a loss. Any help is welcomed to get this thing running.
Old 05-25-2017, 01:33 AM
Clean again. A good soaking and air blast afterwords works well.
Verify that your diaphrams are not cracked when you inspect. Float height is a must needed check too.
Welcome to KF
jay bird
08-25-2010 01:30 AM
Dr. Snake
02-10-2009 07:40 PM
RandyE
03-24-2008 11:31 PM
jnjcaldera
05-17-2007 07:18 PM
jsage
09-20-2005 01:08 AM
Quick Reply: Vulcan classic 1500 carburetor adjustment
