DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Increase power on a 250KLX
Old Sep 10, 2019 | 12:33 PM
Russ66's Avatar
Default Increase power on a 250KLX
Hi I have a KLX 250 66 plate. Im not sure if this is correct but I think this must have a power restriction on it as in all gears excpet 1 and 2 it will not rev up above 7k revs in any of the gears ! There seems to be a loss of power and if this wasnt the case im sure the bike would be alot quicker ?
i did read a thread about something to do with the swithch to the clutch needs bridging to resolve this issue.
Can any one help?
Old Dec 21, 2019 | 07:49 PM
RC Pilot's Avatar
Carb or injection?
Old Jan 16, 2020 | 01:40 AM
dtrackermslazgromthailassi's Avatar
Some dtracker/klx250 have ignition restrictor where on some gears it will not rev past 8k unless the clutch is pressed in. the "derestricting" seen on some places is simply connecting the clutch switch permanently(you can do a jumper cable there at the connector, right at the clutch lever to test temporarely).
mid-life crisis
Oct 26, 2021 05:19 AM
charlemagne
KLX300R
Aug 14, 2017 01:09 AM
piratelife
Mar 12, 2017 07:04 AM
joblesstobias
Jan 12, 2012 02:30 AM
JokersSmile
Jun 17, 2008 03:40 AM
