How to build your own 2 into 1 exaust for a EX 500
I took my wifes 500 exaust apart and built a 2 in to one for her . Pretty easy to do as long as you have acces to a wire feed welder .
Pic one is cuttin the headeer tubes off just infront of the cross over pipe .
Pic two is of the # 2 cylinder pipe marked for removal of the # 1 cylinder pipe to join it and be welded together .
Pic 3 is both head tubes side by side showing there match .
Pic 4 and test fit before bolting up to the bike for a few tack welds. The removal for the final weld out .
Pic 5 the header finshed and ready for fitment of the midpipe and can
[IMG]local://upfiles/32/0A5DABFF0C51437581702F2CE0DB205F.jpg[/IMG]
[IMG]local://upfiles/32/675AACC1438445DD8C9FC520643F785A.jpg[/IMG]
[IMG]local://upfiles/32/A5FAAFC2FF8140DD8DE3CA52EFE58823.jpg[/IMG]
[IMG]local://upfiles/32/FAEA30FD1DCB4BB7B43652782E1BF504.jpg[/IMG]
[IMG]local://upfiles/32/EEB071E714854A30A036004AEE874E02.jpg[/IMG]
RE: How to build your own 2 into 1 exaust for a EX 500
Pic 6 is the back of the header welded out .
Pic 7 test fiting the mid pipe and can
Pic 8 System complete and ready for some high heat paint and bolt up.
Pic 9 close up mounted on the bike .
Pic 10 the 500 is a bit lighter now and has a nicer look IMO .
[IMG]local://upfiles/32/1F7ED8FEBBC4448B96CEED2DC717F6FF.jpg[/IMG]
[IMG]local://upfiles/32/DA3E022A8D884B4EAD10F383FEFB5DA8.jpg[/IMG]
[IMG]local://upfiles/32/55EE36F4CF6E4EC3830FBA04793B5AFF.jpg[/IMG]
[IMG]local://upfiles/32/57C67C4FEBD74B199437E2BB50EED0C0.jpg[/IMG]
[IMG]local://upfiles/32/90F441C2057D4753915E189A1D59620E.jpg[/IMG]
Pic 11 making the can flow a little better by removing the baffle .
Pic 12 making use of my tire machine to knock out the inner screen and break lose the baffle I just drilled lose for final removal .
Pic 13 baffle removed .
Pic 14 left side pic
Pic 15 Rear view pic .
Amber my wife is very happy and so am I since I saved $300 on buying a full system . Next I need to paint the front fairing for her.
Something with a custom look .
[IMG]local://upfiles/32/F18C6723F10D4364B0F0405AE0B4BF9E.jpg[/IMG]
[IMG]local://upfiles/32/3BBD7F7FCAD145118F6127C11BABA84F.jpg[/IMG]
[IMG]local://upfiles/32/8FEF81C4411D4444B1F41FE1DE6217B0.jpg[/IMG]
[IMG]local://upfiles/32/1601FF0D08DC44099CAFBFE13C19478A.jpg[/IMG]
[IMG]local://upfiles/32/18F9099AC67045FEA441F3E84DC4A174.jpg[/IMG]
I have also built severalfull systems for the ZRX 1200 and 1100 .
Thank you . Here are a few pics of a system I built for a friend using my 1200 as the template for fitment .
[IMG]local://upfiles/32/65F38AAB01F34974A7C0E9BC7CCA0611.jpg[/IMG]
[IMG]local://upfiles/32/488F7965CE3941E7948F6881C3D734CA.jpg[/IMG]
[IMG]local://upfiles/32/8047B38E02284D359BFFED8FB92E8A52.jpg[/IMG]
[IMG]local://upfiles/32/07B8161C9AEB4B4FB9851EDB8B0DF3A4.jpg[/IMG]
[IMG]local://upfiles/32/F14579E479D24F92819EC18C16172114.jpg[/IMG]
