DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
EX500 Valve adjustment spec's needed
Old May 3, 2007 | 08:43 PM
rickthefix's Avatar
Default EX500 Valve adjustment spec's needed
Hey guys & gals !
Just picked up a 1990 EX500 last week. Been cleaning it up, repairing oil leaks & repairing the body work & touch-up painting. Starting to look really good, again. The prev. owner had just on new pirelli sport demon tires, new RK chain & sprockets, pads & shoes.
But one thing he said it may need is valves adjusted. I need to adj the valves on it too. I need the intake & exhaust gap spec's for these engines. I'm going to order a Clymers or Haynes manual soon, but wanted to get itchecked/adjusted before I start riding it.
Can any of you send me the spec's? Been mechanicing for almost 40 years so this should not be a big deal!
TIA,
Rick-the-fix
Old May 4, 2007 | 09:50 PM
rickthefix's Avatar
Default RE: EX500 Valve adjustment spec's needed
I found this on another forum I signed up with this morning & wanted to share it with you all.
Good Luck!
EX 500 AND NINJA 500
VALVE ADJUSTMENT
This procedure is very simple and applies to almost any rocker arm engine. Few tools are required and they are simple ones at that.
Why: Valves are adjusted to maintain some clearance between the operating mechanism and the valve seat, to assure the valve closes on the seat for a good seal. If this fails to happen the engine will run poorly and damage could result. The amount of clearance is determined by the design of the valve train and the mfg. Experience as to wear life. Wear will usually decrease the clearance. (tighten) as the valve sinks deeper into the seat.
Generally the settings are done cold and allowance for heat expansion is included in the recommended settings. Deviating from these settings is a bad move, unless you know more than the manufacturer does (you don’t)
Tools required:
10 mm box wrench
Medium flat blade screwdriver
Feeler shims .005 .007 .009 two of each recommended
Procedure for EX500:
Drain the coolant (oils ok)
Remove the tank, right side coil, coolant pipes (the hoses can be left on).
Note: the carbs can be left on but it’s a lot easier if you remove them too.
Remove the cam valve cover
Remove the two copper oil lines
Remove the plugs in the left side engine cover
Remove the spark plugs (put a wad of paper towel in the cavity to prevent dropping something into the plugholes (this is a bad thing).
Using a 14mm socket wrench turn the engine over in a clockwise direction until the “C†mark on the flywheel is visible in the small inspection port and the cam lobes on the #1 cylinder face away from the rocker arms. (#1 is the right side as on the bike).
Note at this point the cam wheels will show the “IN†mark and the “EX†mark level with the cam box outboard surface (approx.)
Now to adjust the valves check with the feeler gages the space between the Adjusting screw and the top of the valve Intakes between .005-.007 Exhausts .007- .009 if they are within that range your golden (footsing around to make the perfect will gain you nothing).
The next cylinder: Rotate the crankshaft clockwise until the second piston is TDC and the cam lobes are pointing away from the valves. And check cyl#2.
If they are not: loosen the ten mm lock nuts (both) slip 2 feelers under each Screw and adjust hold the adjustment with the Screwdriver and tighten with the box wrench. This can cause the adjustment to change so check again. Using two feelers cancels any wear on the rocker arm to its shaft.
Turn the engine until the other cylinders cam lobes are pointing away from its valves and repeat steps above.
Recommended at this time to re torque the head bolts to 35 lbs.
Also remove and clean the “O†rings from the water pipes and the hole in the head they came out of. Reassemble with grease or RTV to prevent leaks
Tips: Setting the valves on the tight side will improve the engines performance and make it quieter, but shorten the inspection interval by ½
Reassemble.
Sources: Kawasaki manuals EN400 EN450 EX500 Supplement
Old Aug 1, 2010 | 07:21 PM
rotlab09's Avatar
Hey rickthefix........................any possible way you can give me the same info for a 1990 ninja zx750-f4?? Thanks. I've ben having big probs. I just need the valve lash gaping
Old Aug 1, 2010 | 07:24 PM
rotlab09's Avatar
https://www.kawasakiforums.com/forum...ad.php?t=33271
That's the place where i have talked about how the bike is acting. Check it out please
Downs3
Oct 19, 2022 01:11 AM
BrydonJ
May 2, 2014 04:41 PM
Notstock
Jun 23, 2006 01:01 AM
lemac
Apr 22, 2006 07:05 AM
derek
Apr 15, 2006 05:35 AM
