DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
2009 er6n starter removal
Old May 20, 2023 | 01:41 AM
DanZ's Avatar
Default 2009 er6n starter removal
Hi all. My bike (2009 er6n) occasionally just clicks the starter relay when pressing the start button. After several repeated presses of the button the starter eventually works and the bike starts. I pulled the starter relay/solenoid and tested it (applied 12v's to the coil side while measuring ohms (less than 1) on the contacts). There's also battery (12v) at the starter terminal when pressing the start button. My next check would be the starter and its brushes. I have never pulled this bike's starter out before so I referred to the shop manual. It looks pretty straight forward with removing the 2 mounting bolts and pulling it out. However, there doesn't appear to be enough clearance between the frame and throttle bodies. The other side of the bike looks just as tight.Am I overlooking something? any help or guidance would be appreciated!
Well maybe I should just ask, has anyone ever removed a starter motor from a 2009 er6n? If so could you please tell me how you did it? Thanks in advance.
zzcadillac
ZZR 1200
Sep 9, 2022 01:49 PM
Jdh4321
Aug 1, 2011 06:54 PM
cj650lake
Jul 31, 2011 05:35 PM
carol1966
Oct 5, 2008 10:55 PM
Nitrospaz19
Jul 30, 2006 11:48 PM
