-   Classic Sportbikes (https://www.kawasakiforums.com/forum/classic-sportbikes-79/)
-   -   Oil Cooler Hoses (https://www.kawasakiforums.com/forum/classic-sportbikes-79/oil-cooler-hoses-16155/)
blane10 Oct 5, 2007 03:38 AM
Oil Cooler Hoses
Hello, can you get after market oil cooler hoses? I had a crack in one . Found some salvage butit also cracked. So I guess Ihave to get some new ones. The OEM oneshave a flange on them. I tried to get it repaired at a Hose & Fitting Supply, they told meit was not possible that I would have to go back to OEM.I found a supplier HEL Performance in the UK that mightcarry them. I would like to buy the flanges so I can have them made or complete ones. I can buy both of them OEM for $280.00 a little high for hoses . I would rather have braided ones .Any way, any suggestions I would greatly Appreciate it. Thank You , Blane
jeffzx9 Oct 6, 2007 01:28 PM
RE: Oil Cooler Hoses
YEOW!! 280 bucks for HOSES?? There's gotta be a better way, and I would keep looking until I found it. I'd check the specs on the actual pressure in the hoses. Some bikes (like the old Z-1's) had low pressure lines. I'm sure somebody makes a flange kit that you can use on aftermarket hoses. I wouldn't trust any salvage parts for this application.
If you've ever had an oil cooler hose leak while you're riding, believe me, its a wild ride.
If you locate a fitting crimper kit, let us know; it may be handy to have in the toolbox.
Dragone#19 Oct 6, 2007 09:07 PM
ouch! the cost does not seem right for the application. oem is not that much is it?
johnp Mar 2, 2008 08:25 PM
blane,go to an industrial supplier..one that handels hose for plants and mills they can help u..gl
