Ltd750 1982 Engine start problems.
Hello..
I need help here. Theres no sign of eltricity when i turn the key on? I was riding, then i stopped. Then i wanted to ride again and turned the key on. When i pushed the START button engine just shutted it down. From then i cant start my bike. What can be the problem? |
You can verify your ignition switch with a multimeter. Hit up your factory manual electrical section. Good luck.
Welcome, Is. The short story is, on a bike that old, a multitude of things could be causing your problem. However, always start with the easy items. Double-check your electrical connections; battery, ground, starter, etc. etc. How old is your battery? Charging system working OK? Will the engine run if you bump-start it?
Let us know.... |
