2007 Vulcan Meanstreak clutch problem
I have a 2007 Kawasaki Vulcan Meanstreak SE. I just did a complete engine swap everything went well and it started up fine. I just need to do some fine tuning on the idle since it's a new engine. the new engine didn't have the clutch slave cylinder so I put my old one on the new motor. I changed break fluid for the brakes and it went fine. I changed the clutch fluid which is the brake fluid dot 4 and the clutch lever won't pull in at all. It's rock hard. Any idea on what happened or what's wrong?
i double checked on my old engine if I transferred everything and turns out, I forgot the rod. Simple, rookie mistake. Works great now. Thank you.
QUOTE=MaverickAus;534793]Sounds like a piston is stuck either in the master or the slave.[/QUOTE]
BigBadFord
Jul 27, 2008 08:05 PM
mnkibler
Mar 30, 2007 03:25 AM
whah
Sep 12, 2006 08:26 AM
LOWANDMEAN
Feb 8, 2006 08:00 AM
