2003 Vulcan 1600
Old Mar 13, 2018 | 09:22 PM
rckartie's Avatar
Default 2003 Vulcan 1600
Good day everybody,
My first ever post goes along with my first ever electrical? issue. on this bike, 2003 Vulcan 1600, 76000 km. Turn key on and neutral light comes on a bit slowly, digital screen stays dark, can hear the fuel pump ticking for a bit . Starter does not turn over at all. Thinking battery (fully charged with ( but older) or starter relay or starter fuse.
I read one thread where I should follow positive cable to starter to check fuse on top of starter. Do I have to take off big side (clutch/transmission) cover to get at fuse??? I lifted gas tank for a look, moved wires connections and for a brief moment the digital display lit up and after 3-5 seconds only a weak green light on neutral light. will be checking for loose,broken,grounding out wire somewhere? Taking battery in for load test now, mumbling about cheap batteries. Am going to use a car battery to see if starter and instrument panel work with a proven battery.
Any help appreciated. Duncan BC Canada
Cheers, Rick
Old Mar 13, 2018 | 09:25 PM
Rick,
I'm not sure where the fuses are located on that bike, but I'd certainly try jumping from a car battery first (with the car NOT running). Then check the primary connections, particularly to the battery (clean and tight), starter, AND GROUND. It sounds like you have a dying battery and/or poor connections.
Old Mar 14, 2018 | 02:45 AM
rckartie's Avatar
Originally Posted by IDRIDR
Rick,
Thankyou.
Sure enough, was the battery. Went from a 14 amp battery to a 18 amp. All good .
gnabzihw
Jul 9, 2022 09:35 PM
MICHIGANWIL
Jul 27, 2007 03:55 AM
gnabzihw
May 31, 2007 02:33 PM
Dugg
Dec 13, 2006 02:15 AM
Dugg
Sep 21, 2006 02:43 PM
