Help 99 1500 classic oil light on
Hi,
I have a 99 1500 classic. Was taking it down for inspection, first ride of the year, and oil light came on, also engine started knocking. Got to garage ( only 3 miles) did inspection and mechanic said we should try changing oil filter. We did that....nothing. only 200 miles on last oil and filter change. This was an auto shop not a motorcycle shop. Changed oil, cleaned strainer, which was not even dirty. Light still on. Bike has 35k on it, has been well maintained . Is this a bad pump ?? Pressure sensor ?? Where is the pump if it's bad ?? Any help is appreciated !!! Jim |
If it's knocking it's not the sensor, I'd suggest oil pump or a blockage somewhere. No clue where it is sorry.
It could be the POG Plastic oil gear. On the 99s the oil pump drive gear is plastic. There is a fix if you didnt screw up the motor.
Judges oil gear look it up on the net |
