Final gear oil change
Can mobil 1 Racing 4T 10x40 Full Syn be used to change the Final Gear Oil? On a 1500 Drifter
Welcome To Kawasaki Forums.
They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there. |
Welcome to KF.
Not really sure on an answer to your question. The manual states API GL-5 Hypoid gear oil, SAE90 at above 5 deg C (41 deg F)and SAE80 at below 5 deg C. For the 94-97 models A GL-6 rated hypoid gear oil can also be used. |
This might help: http://www.gadgetjq.com/gearcase_lube.htm
Simple answer is no. That is an engine oil. Get some 75/90 GL-5 rear gear oil and be done. I like the Valvoline Full Synthetic
