Hard starting ZRX
Old 11-25-2007, 02:06 PM
hokie01's Avatar
Default Hard starting ZRX
I'm a noob to the zrx and have tried to get this thing to start for two days now and have had no luck,it's around 35deg outside and it cranks just fine but will not catch.It has sat for a week .any suggestions,I even gave it a shot of starting fluid as a last resort and still no luck.[&o] I don't have an owners manual to give me general starting procedures.
Old 11-25-2007, 04:31 PM
Default RE: Hard starting ZRX
Catch mean firing? Pull a plug and check the condition.
Old 11-25-2007, 06:45 PM
jeffzx9's Avatar
Sure you got spark? Pull the plug, lean it against the head and crank it over to see if there's any spark at the gap.
Old 11-25-2007, 08:26 PM
hokie01's Avatar
It ran fine last week and trying to start it yesterday and today I may get a little pop here and there but no fire.I called the guy I bought it from and he suggested pointing a salamander heater towards it for a few minutes to warm things.I got out of him thats what he did when he knew I was coming up.
Old 11-25-2007, 08:59 PM
KevyzToy's Avatar
Don't give it any gas when cranking. Pull choke all the way open and hit the starter. If you've been cranking the throttle while starting, you've flooded it. .
Old 11-26-2007, 01:10 AM
hokie01's Avatar
nope never hit the throttle until all other things failed,I even drained each carb and put it to prime for about 30 second or so to refresh the gas.I then tried unsuccesfully again and open one carb to make sure fuel was there.What next,drain each carb again and pull the plugs and replace them. I know every bike has it's own quirk for starting and just have to learn this one.
Old 11-26-2007, 10:26 PM
KevyzToy's Avatar
At this point, I would pull the plugs. Sounds to me like they are fouled. Some how it's got flooded in my mind.
The REX is not a contankerous bike. At least mine aren't. I've started mine in low 40's with no problem. Open choke, hit the starter, warm up for about 30 seconds, and go.
Old 11-27-2007, 02:24 PM
hows it going hokie?? is it running yet?
Old 11-27-2007, 09:20 PM
hokie01's Avatar
haven't tried for a few days. (workin)
Old 11-27-2007, 09:39 PM
workin....wtf[>:]get that thing running so you can play hookie
Quick Reply: Hard starting ZRX
