PDA
View Full Version : KLX 250S
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. 2006 klx 250 for sale
  2. Broken magnet speed sensor.
  3. Headlight gone dead?
  4. Cam Girdle help
  5. DG MUFFLER for sale.
  6. Moto Pro Suspension
  7. 2001 EFi model - airbox mods
  8. Klx250sf rear shock help
  9. Oversized Handlebars
  10. Honda's self-balancing bike
  11. 2011 KLX 250s Mods
  12. Performance Exhaust choices and considerations.
  13. 2009 KLX250S race sag, .46 and 6.2 Springs, 230 lbs rider
  14. KLX250S / SF crankshaft bearing lubrication
  15. Weird wires please identify
  16. kx250 rear fender mod
  17. MOSFET R/R mounting issue
  18. Jump start with cigarette lighter port?
  19. Error Code 32, Subthrottle Sensor Malfunction
  20. Front fork oil
  21. Big bore & cam timing mod
  22. Chain slider?
  23. Fuel pump drains battery - ignition off
  24. Newbie wants input
  25. KLX250sf to a KLX250s 2009 Model.
  26. Need technical help FI 250S
  27. Charging Fun
  28. Is the temp warning light supposed to come on with Key ?
  29. Ims tank
  30. TM36-68 carb question
  31. Previous Owners!.... (Rant warning)... *grin
  32. What all do I need to rejet?
  33. Third Gear Feels Rough
  34. cooked my catalytic converter?
  35. Side stand switch eliminator bypass
  36. Bought my first bike...not happy with how it starts
  37. Should I rejet myself, or hire someone?
  38. Looking for a dedicated woods bike....
  39. Anyone identify this?
  40. fmf powerbomb header noise?
  41. Does this sound normal?
  42. Klx 250s - timing off but valve clearance good?
  43. Vibration when releasing clutch
  44. 2017 Beta 300 (2-smoke) is street legal ...!
  45. useful commuter mod - lower front mug guard.
  46. Spart arrestor kit=wtf?
  47. KLX 250S speed sender removal ???
  48. KLX250 exhaust cam replacement needed
  49. '09 KLX250S Fork spring weight for 230lbs rider?
  50. Stuttering
  51. First Post, 340 Kit Install etc.
  52. Carb problems
  53. Stolen and recovered - broken ignition and triple clamp
  54. Fall ride in the pines
  55. Battery choice
  56. help identifying part
  57. Engine "ticking"?
  58. MCM on a 300cc (292 actually) yay or nay?
  59. Be Careful!
  60. 07 KLX250 Electric Start Problem
  61. Front end shake/loose
  62. Big Bore Time!!!
  63. size hone for KLX300R cylinder?
  64. KLX riders in Sydney (Australia)
  65. FYI manual fan switch
  66. New Throttle
  67. Going from an sf to an S
  68. Anyone want stock carb?
  69. Why is my KLX250s hard to start after it sits for more than a few days?
  70. Stock carb settings
  71. Kibble White valves
  72. Any melted B&B stickers? Normal or I ran too hot?
  73. Dual Rad fans
  74. Will this triple clamp fit a first gen KLX250s?
  75. Dyno Charts: Stock vs Lidless+Slipon VS Lidless+Full FMF+MCM
  76. Need Suggestions for Thumb Brake
  77. Anodized engine farkles?
  78. If you have a pumper carburetor please chime in...
  79. 2006 KLX, need longer clutch cable
  80. Dyno Charts: MCM vs Stock Cam Timings
  81. Dyno Charts: 2013 KLX250 , Stock vs "Uncorked"
  82. Dyno Charts: Houstons4 2013 KLX250S, effects of 1N and Stock Spring
  83. Dyno Charts: Lidless+Slipon VS Lidless+Full FMF+MCM
  84. Playing on the KLX250s
  85. Dirt Tires
  86. 06 250s carburetor rebuild
  87. Marcelino Cam Timings VS Stock Timings on the DYNO
  88. No Electrical Power At All (2007 KLX250)
  89. Which brake pads ? KLX351sf
  90. Burned Filter and Cage
  91. Rode to the Top of Saddleback Mountain, SoCal
  92. Pika's KLX250 FMF exhaust system on my '07 KLX300R
  93. Where to get KLX250s wheels
  94. Last Sunday's ride video's.....
  95. fuel controller
  96. ADV vs MX helmet
  97. Looking for 2012 KLX250s Plastics
  98. Ride report teaser...
  99. Radiator Guards, need better protection....
  100. 09' FMF exhaust on 06' model?
  101. Longer cables on new bars
  102. wierd sound during load :confused:
  103. Looking For Plastics
  104. California emmisions garbage
  105. 2009 KLX Exhaust and Skid Plate in Classifieds
  106. Carb issue when the temp drops
  107. KLX-fork swap
  108. Anyone running motoz tractionators?
  109. 2006 KLX 250 Service Manual
  110. New rider with a 2007 KLX250 looking for suggestions
  111. I Got My New Pipe!
  112. Dyno Charts and Tuning 2013 KLX250S
  113. Do clutch cables stretch when warm - older cable?
  114. Front Fender for 2006 KLX250s??
  115. Bike acts like it has run out of fuel after using only one gallon
  116. Preload spacer for KLX250sf
  117. refoaming my seat
  118. ibration reduction
  119. stock foam and cover for sale
  120. Any broken subframes b/c of Rotopax?
  121. Bought a KLX300 cylinder. What gasket kit do I need?
  122. rear end squeak
  123. Exhaust Mod
  124. Dex-cool vs Green Coolant
  125. KLX250 EFI hard to start when warm
  126. Bogging Again
  127. RPM question from a NOOB
  128. time for the KLX to go
  129. Anyone done the TAT on a KLX351?
  130. Klx250SF fairings?
  131. Clutch and brake lever reach
  132. 09 klx250s gear canceller
  133. Selling my 2009 KLX250(351)SF
  134. Highway speed hiccup
  135. Power loss on highway, motor won't turn forward
  136. New Member KLX250SF
  137. Paddle tire OR ??? going to the sand dunes
  138. Dyonjet Fuel Economy
  139. Full exhaust for sale
  140. Jetting for Higher Elevations
  141. Acerbis tank is a top tier mod.
  142. Seized chain adjustment bolt.
  143. Klx 450 jetting w/ fmf system
  144. My KLX 250sf Tail light Job.
  145. 2007 klx 250s, dj2152 jet kit w/ fmf q4 stock header, lidless with uni filter
  146. Jetting for new exhaust and air filter
  147. Need part 27010-1199 warning switch
  148. Slip on for Aus klx250s
  149. Headlight bulb replacement
  150. how to clamp cr style brake line.
  151. Edge tail light?
  152. Long winded over heating question....stumped..WTF????
  153. Plastics?
  154. New Rider
  155. Acerbis hand guards & pro taper bars question
  156. Choke won't stay pulled out
  157. Different Gearing
  158. Helmet Opinions!
  159. call from the dealer
  160. New Snorkel needed.
  161. Tire Choice...
  162. Cam Chain Tensioner Sound
  163. Can anyone kick start their KLX?
  164. KLX 250 wont start - Red FI light always on
  165. exhaust torq specs
  166. binding while hand cranking
  167. 2016 KLX/D-Tracker - end of production?
  168. flat proof for dual sport
  169. Weird ticking noise at 5k-6k rpms
  170. Where too start... Mods
  171. Coolant temp light
  172. 2010 KLX250s Wont start unless you give it gas
  173. Off the wall question... will seat/tank/shrouds from a KLX300R fit a KLX250S frame?
  174. Led headlight causes engine miss
  175. Hello, thanks, and a question!
  176. Trail Tech mount on '06
  177. 2009 KLX 250s oil leaking from sprocket?
  178. 4-Stroke Novice did the MCM plus a few other mods
  179. Trouble with longer throttle cables
  180. Kawasaki Overload... Happy 4th of July Everyone!!
  181. (Another) tire question
  182. 300 cylinder on 250S - do we lose any top end power?
  183. 2007 KLX250s - Clarke tank fitment
  184. KLX 250 rear side panels
  185. A scary incident and need to see your accesory lights
  186. Exhaust years
  187. Frame guards and fender brace.
  188. Frame guards and fender brace.
  189. 351 and pumper, 1000km (625 miles) later
  190. 2007 Slip On Exhaust Fitment
  191. Fuel Line Locations
  192. 06 Rear Fender question
  193. Light tick sound?
  194. Klx250 tuning
  195. Front wheel brake spacer
  196. Let's talk about my ass....and an aftermarket seat
  197. Linky to suspension info
  198. Help needed. Help appreciated!
  199. Got my new Shinko's on my SF
  200. The KLX aftermarket is awful!
  201. gear leaver oil leaking
  202. Muzzy Status?
  203. Head ight bulb
  204. 2007 KLX250 triple clamp spacing
  205. eratic carb behaviour
  206. folding levers?
  207. Which year model to choose?
  208. My first tyre change!
  209. 351 Install Help
  210. Suspension Adjusting... :)
  211. Help with raising forks / handlebar
  212. does this fan ever work?
  213. Airbox, EFI, wut?
  214. why does crf100 have more snap than my 250?
  215. Need DOT approved tail light
  216. Do I need new rings? 351bb
  217. Best Tires for 30%/70% Street/Dirt Use...
  218. Need a better seat..
  219. Change front or rear sprocket?
  220. Front Sprocket Oreintation
  221. Rear brake fluid reservoir looks empty?
  222. Dead battery? Help
  223. Emissions equipment and cherry red exhaust myths
  224. How to reset clock? And pannier bracket mounting?
  225. I need some help from riders I've helped...
  226. New Bike, Squeaky New?
  227. This Really Sucks!
  228. Quick tech help needed broken fork clamp stud
  229. New 2014 KLX 250s Air Filter Warning?
  230. WTF is up with my left fork leg?
  231. Klxster's CDI Ignition Curve Project
  232. Significance of Ignition Timing on US KLX250s...
  233. Mid range rpm noise
  234. 06-07 KLX250s Will KLX300R wheels work? Any other choices?
  235. Gearing for two wheels
  236. Octopus/Jellyfish Vent Hoses on Gas Tank...
  237. DJ to Keihin Jet conversion chart.
  238. rear wheel for 2011 klx250s
  239. MASSIVE differences between N1TC clip positions....
  240. Stumble between idle and mid throttle
  241. Rear Spring Upgrade
  242. sidestand and clutch safety switch removal question
  243. klx250s 4000km race
  244. Help Part Identification
  245. run the KLX with no mods?
  246. Request: Pictures of cable/wire routing under gas tank
  247. IMS Plastic tank shroud bolt insert spinning in tank......???? Now what...????
  248. Devol 1" Lowering Link
  249. Clarke gas tank installation (06-07 models)
  250. Bent front rotor - are rotor protectors worth the cash?
