View Full Version : KLX 250S
- Any melted B&B stickers? Normal or I ran too hot?
- Dual Rad fans
- Will this triple clamp fit a first gen KLX250s?
- Dyno Charts: Stock vs Lidless+Slipon VS Lidless+Full FMF+MCM
- Need Suggestions for Thumb Brake
- Anodized engine farkles?
- If you have a pumper carburetor please chime in...
- 2006 KLX, need longer clutch cable
- Dyno Charts: MCM vs Stock Cam Timings
- Dyno Charts: 2013 KLX250 , Stock vs "Uncorked"
- Dyno Charts: Houstons4 2013 KLX250S, effects of 1N and Stock Spring
- Dyno Charts: Lidless+Slipon VS Lidless+Full FMF+MCM
- Playing on the KLX250s
- Dirt Tires
- 06 250s carburetor rebuild
- Marcelino Cam Timings VS Stock Timings on the DYNO
- No Electrical Power At All (2007 KLX250)
- Which brake pads ? KLX351sf
- Burned Filter and Cage
- Rode to the Top of Saddleback Mountain, SoCal
- Pika's KLX250 FMF exhaust system on my '07 KLX300R
- Where to get KLX250s wheels
- Last Sunday's ride video's.....
- fuel controller
- ADV vs MX helmet
- Looking for 2012 KLX250s Plastics
- Ride report teaser...
- Radiator Guards, need better protection....
- 09' FMF exhaust on 06' model?
- Longer cables on new bars
- wierd sound during load :confused:
- Looking For Plastics
- California emmisions garbage
- 2009 KLX Exhaust and Skid Plate in Classifieds
- Carb issue when the temp drops
- KLX-fork swap
- Anyone running motoz tractionators?
- 2006 KLX 250 Service Manual
- New rider with a 2007 KLX250 looking for suggestions
- I Got My New Pipe!
- Dyno Charts and Tuning 2013 KLX250S
- Do clutch cables stretch when warm - older cable?
- Front Fender for 2006 KLX250s??
- Bike acts like it has run out of fuel after using only one gallon
- Preload spacer for KLX250sf
- refoaming my seat
- ibration reduction
- stock foam and cover for sale
- Any broken subframes b/c of Rotopax?
- Bought a KLX300 cylinder. What gasket kit do I need?
- rear end squeak
- Exhaust Mod
- Dex-cool vs Green Coolant
- KLX250 EFI hard to start when warm
- Bogging Again
- RPM question from a NOOB
- time for the KLX to go
- Anyone done the TAT on a KLX351?
- Klx250SF fairings?
- Clutch and brake lever reach
- 09 klx250s gear canceller
- Selling my 2009 KLX250(351)SF
- Highway speed hiccup
- Power loss on highway, motor won't turn forward
- New Member KLX250SF
- Paddle tire OR ??? going to the sand dunes
- Dyonjet Fuel Economy
- Full exhaust for sale
- Jetting for Higher Elevations
- Acerbis tank is a top tier mod.
- Seized chain adjustment bolt.
- Klx 450 jetting w/ fmf system
- My KLX 250sf Tail light Job.
- 2007 klx 250s, dj2152 jet kit w/ fmf q4 stock header, lidless with uni filter
- Jetting for new exhaust and air filter
- Need part 27010-1199 warning switch
- Slip on for Aus klx250s
- Headlight bulb replacement
- how to clamp cr style brake line.
- Edge tail light?
- Long winded over heating question....stumped..WTF????
- Plastics?
- New Rider
- Acerbis hand guards & pro taper bars question
- Choke won't stay pulled out
- Different Gearing
- Helmet Opinions!
- call from the dealer
- New Snorkel needed.
- Tire Choice...
- Cam Chain Tensioner Sound
- Can anyone kick start their KLX?
- KLX 250 wont start - Red FI light always on
- exhaust torq specs
- binding while hand cranking
- 2016 KLX/D-Tracker - end of production?
- flat proof for dual sport
- Weird ticking noise at 5k-6k rpms
- Where too start... Mods
- Coolant temp light
- 2010 KLX250s Wont start unless you give it gas
- Off the wall question... will seat/tank/shrouds from a KLX300R fit a KLX250S frame?
- Led headlight causes engine miss
- Hello, thanks, and a question!
- Trail Tech mount on '06
- 2009 KLX 250s oil leaking from sprocket?
- 4-Stroke Novice did the MCM plus a few other mods
- Trouble with longer throttle cables
- Kawasaki Overload... Happy 4th of July Everyone!!
- (Another) tire question
- 300 cylinder on 250S - do we lose any top end power?
- 2007 KLX250s - Clarke tank fitment
- KLX 250 rear side panels
- A scary incident and need to see your accesory lights
- Exhaust years
- Frame guards and fender brace.
- 351 and pumper, 1000km (625 miles) later
- 2007 Slip On Exhaust Fitment
- Fuel Line Locations
- 06 Rear Fender question
- Light tick sound?
- Klx250 tuning
- Front wheel brake spacer
- Let's talk about my ass....and an aftermarket seat
- Linky to suspension info
- Help needed. Help appreciated!
- Got my new Shinko's on my SF
- The KLX aftermarket is awful!
- gear leaver oil leaking
- Muzzy Status?
- Head ight bulb
- 2007 KLX250 triple clamp spacing
- eratic carb behaviour
- folding levers?
- Which year model to choose?
- My first tyre change!
- 351 Install Help
- Suspension Adjusting... :)
- Help with raising forks / handlebar
- does this fan ever work?
- Airbox, EFI, wut?
- why does crf100 have more snap than my 250?
- Need DOT approved tail light
- Do I need new rings? 351bb
- Best Tires for 30%/70% Street/Dirt Use...
- Need a better seat..
- Change front or rear sprocket?
- Front Sprocket Oreintation
- Rear brake fluid reservoir looks empty?
- Dead battery? Help
- Emissions equipment and cherry red exhaust myths
- How to reset clock? And pannier bracket mounting?
- I need some help from riders I've helped...
- New Bike, Squeaky New?
- This Really Sucks!
- Quick tech help needed broken fork clamp stud
- New 2014 KLX 250s Air Filter Warning?
- WTF is up with my left fork leg?
- Klxster's CDI Ignition Curve Project
- Significance of Ignition Timing on US KLX250s...
- Mid range rpm noise
- 06-07 KLX250s Will KLX300R wheels work? Any other choices?
- Gearing for two wheels
- Octopus/Jellyfish Vent Hoses on Gas Tank...
- DJ to Keihin Jet conversion chart.
- rear wheel for 2011 klx250s
- MASSIVE differences between N1TC clip positions....
- Stumble between idle and mid throttle
- Rear Spring Upgrade
- sidestand and clutch safety switch removal question
- klx250s 4000km race
- Help Part Identification
- run the KLX with no mods?
- Request: Pictures of cable/wire routing under gas tank
- IMS Plastic tank shroud bolt insert spinning in tank......???? Now what...????
- Devol 1" Lowering Link
- Clarke gas tank installation (06-07 models)
- Bent front rotor - are rotor protectors worth the cash?
- Buying a KLX
- Dyno Chart Stock KLX250S
- I need a gas cap, anyone have one?
- Video: Valve Clearance Check
- aftermarket dirt wheels?
- OEM Plastics
- Acerbis Supermoto Front Fender
- Wheel interchange
- Bike dies after 7 miles, checked everything, need help....?????
- KLX 250 Graphics Decals Stickers
- Big bore vibrations
- 2009 klx 250s EFI hard to start
- Brake/Clutch levers: OEM vs CNC Pivot style & Shorty
- Lid-less with Keihin MJ and Needles
- Stock spring rates and intended weight
- Are All Dynojet 2152 kits the same ?
- Stock Exhaust Mod???
- Front Fender Brace
- Klr
- Rear Brake Light Harness - Connector or NO?
- 06 klx250s suspension questions
- Building a wee Beastie
- Free JNS Engineering Light Mounts!
- Maintenance of heavily modified KLX 250
- KLX250SF runs and rides fine, then slowly dies
- which slip-on exhaust is on your 2007 KLX250S?
- intro and first mods..will i need carb jetting?
- TM36-68 Tuning?
- What is this part and why is it capped ?
- Radiator shourd plastic search 09-13
- second set of complete wheels cheap
- ADV 101: Using the KLX250s as an Adventure Bike (ARL's Motovlog)
- Sprocket and Airbox mod (UPGRADES)
- New Member
- speedo error on SF also?
- Public Safety Announcement: Engine performance optimization creates unsafe condition.
- kawasaki 14069-1051 BREATHER
- Used KLS250S Purchase
- DynoJet source?
- Snirt run 2016
- 1993 KX fork swap
- Suspension mods for 06-07 KLX250s
- Pro Taper bars not fitting 250SF?
- Question about replacing broken gear change shaft
- Front Fender: Acerbis vs UFO vs Cycra
- Technical Trail Bikes Comparison Table
- Strange wear on 351 big bore kit
- Only getting 13.5V......With solution!!!!
- Linkage and swingarm pivot bolts - best grease to use
- klx 250 sf
- Oil Change, where are the parts online?
- 07 Start-Kill Button/Switch Change
- Engine noise I'm noticing under acceleration
- Spring ride on Illabot Creek Road....
- Acerbis auxillary fuel tank
- Looking for a low buck dual sport jacket? Check this out
- TM36-68 Air Jet?
- Klx250s klx 300R motor swap.
- KLX250 to KLX351 Exhaust Sound
- Difference between klx250e and klx250s
- OEM KLX300R header, mega bomb, or mega bomb knockoff?
- BRP Triple Clamp TCA-5610 (for KLX300R)
- praise for IMS tanks (customer service)
- KLX300 Tank on a KLX250?
- air filter fitting
- WTB Stock Suspension Rods for 2007 KLX 250
- Number plate backgrounds
- Wheel off different bike
- Problem with 2009 KLX 250sf
- It's Alive!
- How thick is the mixture screw plug
