View Full Version : KLX 250S
- 2009 throttle assembly... same/interchangeable with 2014?
- rims for klx250S
- 2013 KLX ...... what is that noise?
- Mikuni T33 fuel mix adjustment screw?
- Fmf powercore 4 + header
- Carb vent hose melted
- Front wheel instal and alignment
- Decel Popping at 6K driving me to want to sell. help
- DG vs FMF Exhaust Upgrade
- Yoshimura RS-2 Slip On Review for 2018 EFI KLX250
- Stator wire protection
- Help! What is hanging off my bike?
- Hey Deej, can you tell about your tailight setup?
- Big bore klx clutch springs
- DIY Fender Mod
- Yoshi RS-2 on 2018 US EFI
- 351 New install
- 2006 klx 250s Red Hot Header
- Rear sprocket for offroad only
- Chinese knock offs
- Black Plastic Radiator/Tank Shrouds on ebay.....
- Con****uity lighting for KLX?
- Taller bigger rider - handlebar and riser question
- FMF Quiet Core mismatch
- Crate motors
- quick question: Seafoam Spray for a rough idle?
- I think I need a clutch rebuild.
- 351, airbox vs FMF…
- 6 Sigma Racing Carb kit
- My KLX is up for sale
- Getting the KLX250S off the ground
- Tools and tips for manual cam chain tensioner
- 13/50 gearing question
- Crankshaft
- When to rebuild and what to replace?
- KLX 250s Help
- Clutch lever movement
- Knuckle WhackJob KLX250 Scrambler
- EFI Information - Let's arm up!
- Planetklx down
- Headlight issue
- No more Dirt Rider magazine
- Engine sound
- Mods that I haven't seen anybody else mention
- New manual cct still seem to have some sound
- Bali Indonesia, anyone from KF close ?
- Short Rider
- knocking noise in gear, fixed
- EFI Fuel Pump Recall? What’s this about?
- Another KLX250S mod thread
- '18 KLX250 mod suggestions
- 2006 klx250s - The blank slate.
- Will a 351 kit work on a 2018 efi
- Wanted: Front and rear rotors for '09 KLX250s
- OEM Handguards
- tire size , what should I get?
- KLX250/351SF valve clearances
- filter oil in the carb???
- powder coating....maybe
- is this suppose to look like this?
- I just wrote to Devol
- Looking for S wheels for my SF
- How to get a LITTLE bit more air into the ratio?
- Anyone Interested in a TM36-68?
- Blew it up after 64,000mi, time to rebuild
- Front and rear brake rotors: 2007 vs 2012 KLX250S
- Anyone know where I can snag a manual cam tensor
- Looking for Hand Guards with Mirrors
- 2018s....
- Drill snapped in starter jet.
- Should I go back to stock pilot jet? need help
- hard restart WTF?!
- KLX 250SF Supermoto Fender or a 2018 KLX
- Differences in head 2009 to 2013?
- tank and carb hoses smell
- EFI Exhaust
- 02 wideband sensor
- BB351...Kinda...finally
- 2003 klx d-tracker
- Dealer setup
- Diameter of KLX250s outer fork tube?
- Cold starting issues, again
- B&B case saver expression of interest
- TM33/34 Tuning after rebuild
- Different plastics?
- 2018 KLX250 Looking for Aftermarket Exhaust but where are the maps?
- klx stock header metal ?
- temp gauge without replacing stock speedo?
- carb help!
- B&B off road frame protectors have arrived! Wow!
- gas tank hose dot colors
- My Experience With The Marcelino Cam Mod
- Tools for 2006 KLX250s for trail repairs
- looking to tune air fuel mixture , the proper way
- Making some progress on the klx300
- What tools and how to remove wheels?
- 2009 evap canister thing , smell
- 2018 klx 250 accessories
- Dumped my bike need new 2009 plastics please help!!
- New guy here, what year KLX250
- Countershaft Sprocket Question
- Hard starting issues
- Anyone with a powder coated green frame? Pics pls
- Headlight delete mod
- Has your cam chain tensioner failed?
- Poll on need for kick starters
- KLX300 Kickstarter into 250EFI?
- Long rides and engine wear , how do I prepare my motor for aggressive riding?
- 2009 klx250s rear shock adjustment
- carb removal
- 2010 KLX250SF Suspension
- How to improve torque at high revs?
- KLX 351 Kit Install
- PSA: 78mm bore kit on Amazon
- is there any link with differences between 06-07 vs 09 and newer?
- '09 stalling like running out of fuel (solved)
- Looking to add some power
- 2007 KLX 250s mods
- KLX300 (1997/1998) Exhaust Cam Change
- Dash cam ???
- 2003 Klx 250 d-tracker
- KLX Speedo/Tacho Cluster
- Tire recommendation
- 351 Tuning Questions
- 2013 Exhaust Mod
- Klx 250s cross country
- Guys, thinking of selling a couple of my Kawi's
- cant find exhaust
- need fmf q4 for a 2006 klx250s
- Cheap ECU...would you buy it?
- Please help electrics
- Noisy engine
- Clutch lever pivot
- Reverse front sprocket?
- Seat strap mod?
- 2009 klx 250 shifting issue
- Pumper carb on the fence
- Finally an attractive street bike from Japan
- CarPlay on a motorcycle
- neutral indicator sender
- Current small dual sport options? What's new vs. heavy maintenance?
- engine stopped without full choke
- KLX 250 is back !!
- 2006 Valve Problem
- Light Fuse Box
- Cam mod clarification
- Is this on?
- CO2 inflator
- Front Wheel Installation Sequence Question
- MCM complete, newbie experience
- Pilot Jets
- Learning to wheelie..
- Starter current draw
- question
- '06 KX 250/450 UFO Rear Fender Install.
- Valve cover gasket 3m spray 77
- Web-Cam camshaft. Anyone have one installed?
- 2018 KLX250, We're Baa-ack
- 1995 KLX250 carb parts help
- Wobbly 09 model
- DJ kit for 09sf
- OEM Seat replacement?
- Throttle Tube
- Please help me start my new baby
- KLX250S 2012 Shift lever
- TM36-68 on stock bore.
- Air Box lid with tupperware modification.
- Bill Blue 351
- Engine Noise, what is it?
- Looking for an inexpensive D/S
- big blue 351 kit
- Options for stiffer forks
- Just.... wow.....
- charging problem
- Drove 2006 klx250 without oil, trying to determine the Damage
- Farewell
- 351 burning oil
- Rear Axle Nut - how often to change?
- Is it possible to run a KLX with no battery ?
- KLX351 overheating issue followed by starting problem
- shameless plug
- Front brake caliper slide pin inside hex rounded out
- Ever run 15/39 with 351BB?
- Photobucket
- SF brake rotor and relocation bracket
- Over night starting issue?
- 2010 KLX 351s
- 2009 KLX250S Starting Issues...
- Swingarm protectors?
- New Exhaust
- been away...what's the latest in carb set up?
- Post SuMo Conversion - chain slack
- KlX250SF Wont Start After Carb Clean
- Help me jet?
- KLX 250 questions
- Fork oil weight?
- Hitch mounted bike hauler feedback? (KLX250s)
- Need rad for 2007, will a 2009 fit?
- Cracked block help?!?
- Ticking after valve adjustment
- Help from the suspension gods.
- KLX250s turns over slowly
- Need help, bike won't start
- Smaller, Lower exhaust
- Bike dies when given gas
- Shipping of parts. :)
- Modifying an IMS fuel tank.
- More engine braking with 351?
- Mikuni TM 36-2 versus Mikuni TM 36-68
- Is My KLX351 burning oil?
- Larger fuel tank for KLX 250S EFI
- BB kit for $143
- KLX engine suspension, steering upgrade.
- Clutch not disengaging ,
- Tuning unsettled idle on 351/mikuni
- Hole coming Out of Crankcase! Help! klx351sf
- KLX 250S EFI ., Remote fuel pump.
- jet change, i done messed up. help needed
- STATOR ISSUE - No Voltage or Resistance
- Odd cam timing?
- Before I have sm rims laced on my S hubs
- Wanted: Clutch Cover - 2012 KLX 250S
- Speedo off about 10%
- 09 slip-on exhaust on a 06 ???
- Backfiring EFI KLX250S with FMF Powercore 4: Needs O2 sensor?
- Rear Inner Tube size for stock 2006 klx250s tire?
- 18" wheel in front?
- Rubberized Street Footpegs?
- Voltage R/R Issues
- Bike help
- Engine parts
- Stock exhaust with FMF megabomb?
- Slight cracking/impurity?
- rear shock static sag
- Valve clearance fudge factor
- 351 tm36 Burning oil
- Radiator Fan Switch
- EFI to Carb conversion.
- How to tell is MCM has been done on used bike.
- KLX300 valve clearence
- 09 KLX250s (300 head) Tune Questions
- Race tech gold valve for KLX forks. S or SF ??
- starter idler gear bushing worn at one side.
- Dialing back on the HP, focusing on torque under 6.5k
- I done messed up. 2007 Carb issues
- KLX 331 Valve clearances.
- 2012 KLX 250s issues
- about to change brake lines for first time
- Electronics and heat
- Size of turn signal bullet connectors?
