View Full Version : KLX 250S
- Carb o ring size
- Looking for an instrument cover/lens for a pre-09 KLX250.
- coolant flush
- Keihin CVK 34
- Videos
- 2006 KlX 250 PCV delete
- 2006 KLX250S suspension questions
- No start KLX 250s
- 2020 KLX250 For Sale in New Hmpshire
- Cheap Ebay Rack
- Front Disc cover for 2020 KLX 250
- KLX250S Wheel Interchangeability
- New KLX250s & KLX250sf?
- For Sale in the UK
- It's not right
- Cylinder Head Noise
- Rad protector
- Running leaded gas in carbureted bikes?
- Loving my KLX250SF w/carbs!
- Help - Buying Some Essentials & Spares
- OEM vs Wiseco piston?
- Vote for a new sticky
- Need help with exhaust
- Attempted theft repair/wiring Help
- Air Filter Oil Alternative?
- Custom KLX250 build: Help with Ignition
- Higher compression 300 conversion
- Thanks!! and a needle question
- 2009 KLX owner random questions..
- Seitched wire ?
- Buying an Exhaust?
- 50 tooth rear sprocket
- Alright how much does this matter? Worth replacing or should I just let her hang!
- Ticking sound worse when cold
- 300cc BBK FI question.
- Piston to head clearance
- KLX250 Windscreen Options?
- Who and where to do a 351 upgrade to my KLX-250?
- 2017 KLX won’t start after it was stolen and hot wired
- Cleaning up my rear end
- New KLX250
- Cam question, advise
- KLX250SF for fire roads
- Running problems with my KLX 250s
- KLX250 with 351 kit issue
- Fuel reserve switch KLX 250 S9/SAF
- Kawasaki KLX250 D-Tracker?
- help with part number
- Increasing clutch oil flow to reduce fade
- 2010 250S carburator
- Clutch Chatter with KLX125 plates
- Tire question
- 2019 KLX 250 plastic replacement.
- 2020 Clutch Switch Mod
- air filter question with mods
- Suicide Mission Pt2
- Efi hot start issues
- Possible oil starvation?
- Suicide Mission Pr1
- Kickstand Safety?
- New custom made exhaust
- Info on yet another 351 installation
- 300 piston kit from China
- 2009 KLX250s Leaking gas.
- Shifting issues after lowside - reluctant into first, hangs on upshifts
- 2020 klx 300r muffler
- Issues to Look for when Purchasing Used
- 2009 KLX250sf headlight and tail light not working
- Latest Video (Part 3)
- Old 2007 KLX25s FUSES!!
- 13 rear shock service
- TPS shorted out?
- Need Oil Filter Cap ASAP
- Clutch switch mod
- Front forks
- Modifying axle slot in swingarm
- 2020 KLX250 too lean?
- Adding air pressure to forks?
- Klx250sf idle cut out
- coolant change how often
- 2009 carb hoses what goes where?
- Astraphobia (Video)
- KLX250R exhaust cross compatibility
- Need some info
- Shinko 705's on a KLX250s
- Another KLX351 with CVK
- trade SF fender for an S black
- Larger gas tank for 2014 klx 250s
- ISO 2009 tank plastics
- speedmetal led conversion kit
- Drilling out baffels
- Tail Light Kit Recommendation?
- 2009 klx 250 Dies after warm up - Dealership out of ideas
- Klx 125 exhaust reccomendation
- KLX250 Model Sub Types?
- Suspension setup for 200lbs
- Ophidiophobia
- 5'9 with 31 inch inseam a little worried
- Braaap and getting old
- KLX300 transmission in KLX250s
- Squirrelly bike
- My newest video - Covid Relief
- In need of a klx 250 head
- Tusk DSport Tire Review
- What’s my bike worth?
- Capt Monster's Wasteland/Mad Max KLX: A build thread
- Clutch Slipping with the BB 351 kit
- carb boot install
- Klx250s Headlight
- Oil drip lhs
- Overheating 2009
- small handpump
- Chain guide for 2018 KLX?
- Screw for Q4 Spark Aresstor
- Clutch Help
- Throttle Assmebly Replacement
- 13t Front Sprockets that Fit 2020 klx 250
- 2006 Fork question
- 2009 KLX250S front fork lug removal
- New Video - Rag to Time Warp
- Shorty Clutch/Brake Levers
- Trading Red plastics for Green Plastics KLX250S 2009
- DB killer/Baffles
- The Hurt Locker.
- Lowering Links For Sale - Removed from 2007 KLX250S
- New Video - Soup & Salad
- 06/07 Owners: license plate options?
- Buying a blown KLX250S
- Upgrade cost on new KLX250
- Custom seat
- KLX300R in a KLX250 frame?
- Carb vs f.i.
- Pre-09 wheels on newer models?
- EFI MCM Lidless slip-on tuning
- 2018+ Clutch switch mod
- Dinged crankcase cover replace and protect!?
- help posting signature on this forum
- Trying to muffle intake sound
- Wiring a USB
- 2004-2006 KLX250 tank upgrade
- What is the coolant flow direction on the KLX250/300?
- recomendation for cheap lowering links
- 2009 smog removal
- Road wheels/ Rear Tire width for S model
- KLX351 installed + overheating
- Low charging voltage
- How do you lighten the bike?
- Speedometer display problem
- Look What Came in the Mail Today
- 2014 KLX 250S Compatible Rear Shocks
- 06 KLX250S Suspension Link Question
- Replacement foot pegs
- Buying Used KLX250S
- Now a rod kit for the KLX250/300
- 2008 KLX250S starting problem?
- KLX351 + Barker Exhaust + EJK + MCM
- 2009 klx250sf
- Tires for Dirt
- KLX250SF Knobby Front
- Noob question: carb not draining through drain plug
- Short replacement clutch/brake handles for 2006 KLX250S
- 2009 upgrades started
- About to rebuild my front forks, what weight oil should I go with?
- 2009 KLX 250 s not starting, but electric start works fine...
- Zeta Offset Handlebar Risers
- Is cam chain adjusted correctly? Sound file
- So what am I doing incorrectly? Speed sensor issue
- Has my bike been lowered?
- 1996 klx 250 radiator shrouds
- Manual cam tensioner install
- Not bad but rather unfortunate news!
- double post. delete please
- What is wrong with my kickstand
- Recommendations for cheap chinese head pipe
- Do pre 2009 klx250 exhausts fit on 2009 and up?
- The old WR vs DRZ vs KLX complex, I hope I have a solution
- Painting the rims
- Info Thread: KLX250S EFI with Big Bore (351, 330, 300, etc)
- Last weekends ride video.
- full muzzy exhaust jetting
- Surging at high RPM under load.
- Question about product sent to Canada and other countries
- So...I got the bike pretty much in time to go to lockdown
- advantages/disadvantages of quicker throttle tube
- So, about that kickstarter
- Jetting recommendation for Danmoto slip on exhaust
- Bike will no longer start in gear
- Is there slack for a bar riser?
- WTB: Stock height rear suspension links (dog bones)
- KLX for hard enduro?
- Replacement front forks
- stock gas tank cap vent
- klx 250 vs kx 250f motor difference`
- Route Planning
- ACR Removal or disable on BB 351 ?
- Supermoto wheels
- KX250F Monoshock in KLS250S - Possible?
- Looking for used Tachometer / Tachometer fix?
- New to the Forum... But My Videos Aren't
- Do I need a new clutch, or am I missing something?
- Noisy 13T sprocket
- KLX 300 piston installation
- What springs for 180lbs rider?
- Budget KLX steering damper / stabilizer?
- Need help with 2019 throttle assy
- 351 kit and MCM mod
- Cams worn out
- Help with unknown wire please
- Rear disk rotor - 240mm?
- Damaged Valve Lifter
- Phone Charger/Power Options
- How often you change your fuel line n filter
- Newbie
- D-Tracker 250 engine sound
- Finish durability of Blacked out KLX
- KLX250S Parts list
- Starting free mods-what fuel adjust screws are avail?
- Another KLX 300 cold start problem thread
- 06 klx250 I want to put on a q4 exhaust
- Rear suspension dogbone link length
- KLX 250 Starter Motor replacement options?
- Looking to buy a KLX
- 2011 Fork MOD
- New Owner-thanks to Klxster for advice
- Kawasaki KLX250/300 vs LoncinYF300
- BB351 Bill Blue Update circa 2020
- Pulling in 6th
- First mod advice. *New*
- Carb spring I.D.
- 09 KLX250s suspension linkage rods
- Supermoto wheels
- Wouldn't it be nice and helpful if...
- Anyone do the secondary throttle plate removal mod?
- Ordered a new OEM coil and THIS NGK plug cap. Anyone else. Inexpensive alternative?
- New Thread! Could it be the COIL?!?!?!
- wanted stock oem exhaust for 2007 klx250s
- Carb woes.... is needle adjustable on '09 250s?
- Rear Sprocket
- How much do you think a KLX 250 S with a seized engine is worth?
- Wiring help! Aftermarket fender eliminator with turn signals.
- Klx250s UK Model efi - ejk settings plea for help
- Excessive Blow By?
- High flow
- KLX fails to charge the battery
- Recommended ejk settings
- 2018+ klx250 supermoto conversion
- Ejk
- Ride height.. Has my bike been lowered? Measurement please?
- headlight
