View Full Version : KLX 250S
- 2009 KLX to mod or buy a different bike?
- Acerbis tank and UNABIKER radiator fitment
- The KLX 250S/250SF bible: What service manual is the right one?
- 09 forks combatable with 2012 KLX?
- Oil change question
- Maximum Tyre Size | 2020 KLX250s (AUS)
- Posts
- 2020 klx250 conversion to wider wheels
- 2022 KLX300 and 300SM Radiator Guards
- fuel tank question
- Problem after trying the lidless setup
- Wanted FMF Q4 Hex for KLX250S
- Current Gen KLX Models and Aftermarket Wheels
- Crankshaft bearing
- I'm Baaaaaaaack!
- KLX300SM Mods
- wanted: KLX250 front wheel hub
- KLX250 stator to KLX300?
- Big bore manufacturer
- Klx250s 2013 vs Klx300 2022
- Fitting KX250 exhaust to KLX250
- 2022 KLX300 Lowering Question
- Off road/adventure school?
- Old vs new - KLX300
- Low seat for stock??
- KLX300 engine good for how many KM
- Looking for FMF Q4 exhaust, can trade my Powercore 4
- Selling my KLX650
- Swiftkicker adjustable kickstand
- KLX 300 ECM connector
- T-Rex Racing parts
- Kl
- lidless or no
- Go Big or Go KTM???
- KLX300 - "Unmuzzled" Power Charts Needed.
- Review: Unabiker Radiator Guards
- New guy, same questions
- Knocking Noise 18 Klx250s
- Headlight won't work after touching break light wires with ignition on
- Question for jetting gurus
- 300 Dual Sport vs 300R 2020 plus
- FCR35 problems. Need help please.
- 2001 klx250 starts then shuts down
- Wide Ratio Transmission?
- Review: 2006 Clarke Fuel Tank
- KLX250 Front Brake Line Alternatives
- 13 tooth primary vs Stock 14 - A few words.
- MCM mod and more
- New owner first post
- Been done? Dirt Rider Project KLX300R?
- 2006 KLX250S (KLX250 h6)
- Dunlop D606 or ....
- Krieger MCCT
- Handlebar replacement - drill or cut pin- KLX300
- Are shaved down seats still comfortable?
- Question about shaving seat on KLX 300
- Sprocket & Chain Life on a KLX 300S
- 2018 KLX250 Performance Mods – Help/Suggestions
- New on the 2009 KLX250S EFI! First questions..
- KLX 250 to 300
- New KLX300 in Oregon or Washington for MSRP?
- Shinko 244 ?'s
- Love me some fall riding
- NEW 2012 KLX250S owner & build!
- What is this 6-pin connector for?
- How to clean throttle tube with vulcanized grip klx300
- Electrical Problem: HElP!
- Indonesian Exhaust?
- KLX 300 upgrades for Dual Sport events
- K&N Air filter fitting Klx 250S
- KLX 250 EFI (2009): 4k rpm idle when hot
- New on the 2014 KLX250S EFI! First questions..
- KLX300 EFI Dual sport and KDX Snorkel ok ?
- 2022 KLX300 Dual Sport Stock Handlebar Spec/bend ?
- Swapping 5spd for 6spd gbox on old klx250r
- 2021+ KLX300 Dual Sport
- KLX250 CDI Replacement
- 07 KLX250s Aluminium Radiators
- Rear cam chain guide.
- Klx 83mm piston kit
- OEM 300 piston on a 250
- How can I speed up the warm-up process? (See video link)
- when and why would you need a O2 sensor Delete?
- MCM & ACR Spring
- Mileage jump through time
- Bike paint color
- Repair deep scratches
- Whining / whistling noise from front tire area of 2018 klx 250
- 2006 KLX250S fork valve stack/part
- Radiator screen hole misalignment
- 2009 KLX 250s - Engine stumbling on hill starts
- Main jet and Sprockets
- Self-compiled (DIY) Bike Recovery Kits?
- front wheel mounting
- Speedo problem
- 2006 KLX250 timing marks don’t seem right
- 2021 klx300 shift problem
- TM 33/34 Mikuni flat slide pumper on stock bore (Big Bore in future)
- Stock 2018 KLX250 (EFI) Popping on deceleration
- Clutch shaft not engaging after lubing and reinstalling clutch cable
- A new critter
- KLX250S EFI Big Bore upgrades - success [and failure] stories
- Krieger Cam Chain Tensioners 8/23/21 temporarily down
- 1998 KLX250 (Lx250e) Wiring Help
- KLX250S RPM issue
- Compression test
- Trip report: 850 miles of (mostly) dirt in 4 days
- Need a new frame for a KLX250
- Off road wheels for the KLX300SM
- Oil Level
- Wanted - Carb for 2009 KLX250S
- Rear brake leaking fluid, can't find where from
- Klx 250 efi
- Bike sat a couple years. Crank won't turn by wrench...
- Klx 300 mod advice please
- 2020 KLX250 (Camo) Gas Tank Upgrade?
- Hi guys and gals.. looking for a wiring diagram for a klx 250 fi 2009
- 2005 KLX 250 Carb
- Wanted - Valve Buckets / Tappets
- For sale - 2018 kawasaki klx250s $3800
- KLX250 2010 FI light flashing when pushing start button
- 2009 KLX250s. Which axle nut wrenches do I need?
- @006 KKLX250S stock forks
- New Chain / Sprocket combo observation / ?
- Klx250sf will not idle or barely runs unless full choke
- Anyone running a GCAG Hardcore soft rack on their KLX?
- Help with 2009 KLX250s jetting!!!
- Stock ignition
- 3 top bikes
- klx 331
- Help - Bought used 2010 KLX250s - Australia - carb has been modified?
- Beenie under helmet?
- Help finding 2006 integrated tail light kit
- New KLX300 - cam specs change at all?
- for sale: soupy's 2-4" lowering link and kick stand
- Steering Stem Nut size?
- KLX 250 Digital dash display
- Rich and cutting out off idle
- Need some help advice 2014 KLX250 Theft Recovery
- Let's talk about preload....
- Crashed my 2009 KLX250SF
- 2009 airbox lid
- Should I buy it? Need help
- KLX250/300 tool pouch
- Aftermarket for 300sm
- Front End Shimmy
- Lowering links for a 2019??
- Captive Wheel Spacers?
- Bump start with no spark possible?
- 1994 klx250 problems, wont run
- About Air fuel mixture on klx/Dtracker
- 2009 KLX250SF Carb Tuning Advice
- Front End Squealing
- 2021 KLX300 exhaust questions
- Suspension and General Upgrade for Large Rider
- KLX250S Burnt hole in airbox
- Oil Leaks - Swing arm bolt
- 2018 KLX 250 Cables
- 2021 KLX300 Flasher relay location
- KLX250S Kickstarter Kit info
- KLX250 battery conversion
- Recommended sprocket set-up for Michigan sandy ORV trails
- Highway Dirt Bike hand guard install HELP!
- Buying Used KLX 250S, what to look for / watch out for?
- Tire wear and front end vibration
- Klx300 needle collar
- IMS Larger Fuel Tank KLX 250/300 Dual Sports
- klx351 tear down redo
- Handlebar rookie
- 2021 KLX-300 vs. CRF-300 Rally? Or, KLX-300SM?
- Valve bucket corrosion
- Flasher relay?
- Loose flywheel bolt
- Thinking of Selling 2006 KLX250S
- 09 KLX250s clutch/transmission issue after shift star change
- Tire recommendations- new rider, new (to me) bike - 2010 KLX250s
- Cheap CNC Aluminium Hubs
- Powercore 4 and header
- Wheel bearing help
- KLX250 EFI big bore - is there an actual EFI solution?
- Re-thinking the 351, Head Gasket issues?
- Broken cam chain, broken decomp
- 351 exhaust (KLX300/DG vs Barker)
- Dumb question. Do I need to order a coolant drain crush washer?
- Highway Dirt Bike out of business?
- Newbie from Poland with 2009 EFI: A tale of power: Chapter 0.
- Another pumper question (with IMS)
- What is the circumference of the front Forks for the Klx 250 dual sport bik
- Klr650 seat on klx250
- DJ kit 2206 (klx300) for 09 250s help
- New rear Caliper?
- Rubber plug/seal around front brake and fork?
- KLX250 Carburator
- 2009 Speedometer display LCD not working
- Handlebar bracket mount for Led lights
- Considering a 2021 KLX300, engine vibration question?
- Tail Tidy kit from China?
- One Piece Handle Bar Top Clamp
- Trouble Starting KLX250S
- 2018 KLX250 SuperMoto Wheels
- Swap to EFI for 2009 KLX205SF?
- Choices between models
- Odometer has a faded blob
- Leaky front fork
- New bike! First Post
- Wanted: OEM muffler for KLX250s
- 2019 KLX 250 Manuals
- TOP Speed Question
- Name and model of rear brake/tail light for klx
- What are the light bulb types and led replacements for newer Klx’s Dual sports
- Gear Shift Lever replacement help
- New Member build sheet
- Easy OEM MOD Step by Step w/ Pics & Video
- Wanted: stock dog bones (117mm length)
- Will 2018 KLX250s exhaust fit on a 2010?
- Winter Riding
- Free NIB OEM KDX200 Snorkel - just pay shipping
- Severed klx speedo cable
- Help choosing after market exhaust!
- Stock Exhaust Help
- What's the best suspension valving option?
- Aliexpress top end
- Rims For 2020 KLX250s ???
- Model check. KLX250-H
- Tusk Bolt-on Heated Grips: review
- Throttle response, pumper carb, mileage
- 2006 KLX 250S New Carb Install
- New new new!!! Please help
- Finally finished my KLX250S
- old gas (two weeks old) no start
- klx300 2021
- EFI tuning - what are the options ?
- Fork Rebuild Time?
- First 2011 KLX250s
- Klx300...
- Good place to get oil drain plug crush washers? '09 KLX250s
- More responsive throttle
- Cruising RPM
- Suddenly no power when ignition turned on - Help
- New-to-me KLX250S
- Camshaft cover issue
- Bike still runs with 50% leakdown?
- weird shifter problem
- Carb o ring size
- Looking for an instrument cover/lens for a pre-09 KLX250.
- coolant flush
