View Full Version : KLX 250S
- Hello old friends
- Carb vent T mod?
- suspension adjustments
- spring = son of a bee-sting !
- The KLX and I went our separate ways...
- Adjust pilot without T-screw or removing carb
- Not all 2009 models are CA compliant..
- Am I crazy? (buying second klx)
- Optimum exhaust system length?
- 06 tail rack options?
- little plastic nub behind the clutch handle
- Wanted 09 klx250s complete rear wheel.
- trouble starting when cold
- New York event
- Klx 250sf mods and mpg
- kls250s noob
- klx 250 carburettor cleaning, keihin CVK
- Ghost gear?
- Got a new enduro this week
- Cam Bucket Wear Need Advice
- rejet question where to buy jets
- Klx for sale - uk
- need some new gear recommendations
- 351 power question?
- Tuning Tips For EFI Bikes ?
- Manganese additive in my gas..
- tire changes
- new bike
- This is why bikers shouldn't pass on the right
- Foot Peg Relocation?
- Question about clutch upgrades
- MEGABOMB DYNO TEST-before and after
- Klx250s tach problem
- 2006 klx, who makes a low seat?
- KLX 300 cylinder head on a 250s
- klx450 motard wheels on 2010 klx250s
- I love you UPS man!!!
- Might be back
- Death Valley - ride report
- problems with BB351 after install
- Hatfield McCoy Weekend
- 250sf upgrades
- FYI: MegaBomb header won't fit DG-R Slip On
- Don't like your KLX without a snorkle or lid?
- Question for the KLX
- Kreiger manual cam chain tensioner for sale
- I got some new tires! Shinko 705
- Trouble finding jet sizes
- Problems with starting her up...
- Give me your stock links for my KoubaLink KLX3s
- 351 at Dyno
- getting geared up with a few new items
- New KLX owner! Some newbie questions
- An unusual KLX review
- How to remove headlight bulb?
- new here
- Auxiliary lighting
- DRC wide footpegs
- got a new 2014!
- Boring rear disc info.
- L48 State bike
- a dual sport mule in the barn (with THE stumble!)
- S vs SF side stand length
- Idle speed vs oil pump efficiency/oil pressure?
- Changed oil and problem
- New tires
- Needing an 09 or newer seat cover
- 47T Rear Sprocket
- Why doesn't the klx have a cush drive?
- 2009 to present Axle diameters
- 2009 KLX250SF (Black) For Sale
- Shinko 244 front/705 rear?
- new or used?
- 2007 KLX250s will not start cold, but will bump start or start from a jump just fine
- Restoring shine to faded plastics
- Dynojet Kit questions for 2009+ KLX250s
- exhaust question
- 09 klx250s Kick start
- TM36 with 351 kit jetting request
- Bars to be narrowed
- ?valve clearance adjustment?
- Got impulsive and Bought 2!!!
- Cheap eBay TM36-68
- Oil change
- newbie
- IMS Question...
- more tuning woes
- klx250s black front fender
- D-tracker front, rear Sprocket and chain
- Adding a tach to MY 250 D-Tracker
- Tire size
- Will KLX300R tank fit on 07 KLX250?
- New 2014 Ninja (possibly) with KLX250 engine
- My TrailTech Install
- How much for a new klx250s?
- Kawasaki down! Carb?
- Lowering 2010 KLXs dual sport
- riding gear
- oversized tank
- Ticking on engine startup, goes away when warm but audible @ 4000-6000rpm
- Changed my first tire last night
- starting up a 351 after 12 months in storage
- Darn side stand switch
- Try this next time you're out in the woods
- Idle problem - Idle not steady
- My belly pan is bigger than your belly pan!
- Ride Report
- Mirrors on the KLX
- 16 and 15t sprocket rps
- Anyone using this new Ignitor box?
- engine case crack
- Can't get my bike to run!
- 351 big blue, stock or pumper carb?
- Programming "high" temps on Vapor
- EX500 wheels on KLX
- for sale dg slip on
- Rear wheel centered?
- hey guys im new here!
- ponderings about airflow
- It feels good to be done
- Two Mofos on a bike
- KLX250s to 351 installed!
- List of parts on KLX300 that will fit 250.
- Yay first ride report!
- Dg o series slip on.
- We made it!
- BB TM34 Installed / Weird Idle
- Just installed KLX300 exhaust on klx250
- Beet oil cooler connections?
- Added lighter flywheel today
- How do I fix this road rash?
- Klx250SF Avon distanzia tire review
- Suggestions for Dyno testing of MegaBomb ?
- 2006/07 Clutch Cable Length
- Watching coolant w/ radiator cap off
- New Member '06 KLX250
- First spring ride report
- Gas Mileage
- EJK-Controller KLX250s
- TM36-68 Carb Adjustment Question
- 09 klx 250s misc parts for sale
- New tires
- I got the Gorilla 8017 installed today
- KLX 250 aftermarket Clutch Perch
- Digital gauge / meter quit
- new carb or exhaust on top of 351
- Gearing?????? 15/40????
- Spark plug reading
- Location for GPS Tracker
- I wanna ride!
- oversized bars conversion
- Fun While It Lasted....
- Wheeee Hooooo!
- cleaning out garage
- KLX 300 Parts bike
- Just in case you didn't think it was real...
- What pipe and jet kit?
- So, what is the KLX really capable of???
- High Alititude Jetting for TM36-68
- Lytle creek fire roads
- klx650 timing out/need advice
- Shout out for Stabil
- Stator Wattage
- Puncture repair, while out
- Drilled my air box today..
- What to do after bike takes a nap?
- TM36 pumper duration
- No fire
- Intake Cam - I'm Lucky...
- TM36 and Acerbis Tank Pt II: Cable Length
- BB351 Engine/TM36/Pipe/Tank for sale
- Removing the flywheel
- Thank you KLX forum!
- Ims tank.
- KLX250 rear shock/spring?
- hey i need a bit of help on some "rookie" questions w/the KLX250
- Aussie needs wheel help
- Security Alarm for the KLX - Super cheap!
- My bike was Stolen
- klx 331 jets
- KLX 250s Wheelies
- Problem Installing TM33 Carb On FI KLX250S
- Install a bill blue in colorado?
- Duel Sport 50/50 Tires?
- Anyone try a carb from one of the four stroke 250 MX bikes?
- KLX250s - Where did you mount your GPS ?
- Lowering my KLX250.
- 2006/07 klx2507h pro techs needed
- pilot screw needle stuck in carb
- Levers for KLX250
- SF wheels on my S
- SuperMoto Tires
- Rapid Bike EVO: Total Injection Control
- Coolant Overflow tank
- "zingy" engine above 5k rpms
- What protection do you wear
- Big Als Blog
- Doing the 351!?!?!
- First KLX250S. Good deal, yes or no?
- just posted the klx for sale
- Need help, key won't fit in gas cap.
- 1996 Klx 250 gearbox problem
- Farthest travelled
- Bill blue Kit questions
- has this happened to you?
- Winter Mods
- Dare I start a suspension thread....
- Front brake rotor listed on ebay for $18.95
- 12.000km service
- Wondering
- more mods last weekend
- Location, location, location
- KLX250 IMS tank and FMF Q4 for sale - is there a classified section?
- helmet bug remover
- ninja 250 wheels
- Newbie
- Dg slip on for sale
- BB TM34 w/351 Jetting?
- klx250s best skid plate and where's the bect price?
- KLX choke relocation to handlbar
- Another one "drank the Kool-Aid"
- 09 klx250s backfiring
- KLX250 EFI intermittent power loss, hard starting
- FS: KLX250S Scorpion Skidplate & Zeta Oil Filter Cover
- Selling my KLX
- Street riding
- How sweet does this deal sound
- 331 w/ TM36 jetting at sea level?
- Stock KLX250sf NEWBIE :)
- New To The Forum
- only runs with the starter button pressed
- fork pre load adjusters
- Help! Leaking Gas from Carb overflow tube.
- For those that removed snorkle but still want one
- 2009 kl250s emissions removal
- Rear Swiwgarm Maintenance Question
- GoPro commercial
- Dan Moto Exhaust?
- KLX250s Mods done, is speedo off now?
- Cold starting
- Reckless Drivers Thread
- rear fender
- new 2012 or 2014 KLX 250s which should I buy?
- Trail tech vapor for KLX250
- A KLX box...or...
- You'll kill me for this....
- What should i get?
- Why we maintain our KLX
- 2013 KLX250s - Quick Questions for a starter
- Kx250f parts compatibility for klx250sf
