View Full Version : KLX 250S
- Good info for installing piston rings..?
- Variations on changing the cam timing
- An oil thread?! You've got to be kidding me...
- Anyone return to stock???
- Santa brought me one of these...
- KLX250R vs KLX450R
- Where to buy KLX300 muffler?
- Looking for Muffler
- Never sell your klx
- KLX250 EFI UK 2012 starts then 1 minute later FI light ON?
- Lowering fork dust seals?
- Air/fuel mixture screw thingy... What do you call it?
- Self diagnosis
- pic format test
- MotoTune ported a KLX250/365?
- got a new KLX 250S 2 weeks ago
- For those with 1 1/8" bars
- Need Help!
- 2006 KLX250S clutch lever
- Shock spring lock rings/nuts
- questions about handlebar setup
- Pirelli MT43 thread
- Bike Won't Start - Fuel - Carb Issue? (Float?)
- KLX250S No Electrical Response Whatsoever
- Trail Tech Voyager
- Jet Kits
- Refinishing Plastic
- S/sf difference?
- 2006 KLX Tool Kit
- setting rear sag
- Dirt wheels magazine
- Dents in front rim?
- New to KLX
- Who likes shinko 244's?
- Parts interchangeability (06-07 to 09-14)
- Counter Shaft Sprocket Nut Removal Horror Story
- Oops, dumb question on dynojet spring
- Michelin T63
- New "slide spring" w/ jet-kit - How important?
- seat concepts - how to get in touch with them?
- What's your gearing combination and chain length?
- max rear sprocket size with a 13t/108chain
- exhaus uggetsions to increase low end torque
- upper chain guard
- Water in Gas Tank
- after klx250 what? A buyers guide
- Anybody tried dual exhausts? :O
- Can someone tell me what this hose is for?
- Bernie's timing mod results ! (cue Hallelujah Chorus)
- Good bye and thanks!
- really high idle with choke on...??
- How the CV Carb self adjusts for altitude
- help to contact member
- Anyone used a Dominator Exhaust? only £100 new
- Uh oh winters here.. :(
- Write up on how to fit after market bars (pro taper) to KLX250S
- DIY KLX seat modification (flatten)
- Anyone in UK wanna swap there red plastics for my green 'Monster' ones?
- tci klx 250s parts good/bad ?
- Just bought 2009 KLX250S, help identify 'mods' please
- The toughest question about an 09 250S!
- Acerbis Tank Bracket
- Replacement Throttle Tube for 2006??
- Keihin fcr mx flat slide carb swap
- Just converted my s to a sf
- Air box insert tested +1 kph
- Broken headlamp
- SUP Loosers LOL
- Longer Cables
- Ebay Chinese PowerBomb Install
- X-ring chain failing
- Euro and US Horsepower Difference
- 3 Carb shootout! 34 vs 36 vs 40mm
- Old trailtech endurance
- Spring People
- cylinder head cover removal
- DJ #136 main jet - preliminary results
- ok next improvment on my new baby h4 bulb ?
- i will try not to be a pain in the butt
- starting my klx off on the right foot
- what size bars come stock
- what are you using for a Megabomb heat shield?
- Air filter pods?
- Containers
- '07 250s SM Conversion Thoughts and Questions
- Bars riser and hand guards
- need good handguards
- mcm cam change
- new plastics
- HSR 40mm Mikuni pumper on stock bore ! (Carbzilla Lives!)
- From DynoJet:DJ jets equivalent to same # Keihin
- Leaks Gas When Sleeping
- Testing the 34mm CVK with a/f meter
- From DynoJet: Kit 2152 not designed for Lid Off !
- Tuning the TM36 on the fly
- jetting questions
- CV Carb setup instructions.
- Russian Go-Anywhere m/c vid
- Yet another tragedy
- Where is my Fuel Filter?????????2006
- Bill Blue 331 cylinder compression?
- Paperwork
- Fall Hatfield McCoy Weekend. Oct 3-5
- The latest 100 mile deej ride report
- KLX250S Discontinued?
- Help needed - 351 starting issues. Free Beer!
- 132 main, clip on 4th slot from the top, idle issues
- RORR D/S October 12
- Radiator leak from hose
- Brake Light wires?
- Keeps fouling plugs...
- Front fork springs
- brake light mod
- Road trip to see my cute 1yr old niece.
- KLX 250 cylinder de-glazing
- top hard case
- Utah Sucked this Month!
- ATTENTION klx250 valve springs
- Airbox Snorkle
- Drz400e
- 09 vs 14 Plastics Differences
- rear brake caliper not steady
- What's it worth?
- New FMF
- 2006 KLX 250 low power up top
- 2006 250s Gas Tank
- Curiosity : What RPM do you drive at?
- Who's made most HP on KLX 250 on DYNO
- Do I Need an Extended Clutch Cable
- 07 300 install
- Kick starter for 09 KLX 250
- '04 klx250s...what next??
- Different Mph to Revs Ratio After Oil Change
- My KLX starter turns over but sounds like motor isnt even attached
- What is this
- after maintenance and cleaning process
- Marcelino cam mod how to
- heating problemwith exhaust pipe
- How to install GPS navigation to start with ignition
- Klx351 tm36-68 DYNO!!!
- EJK installation + O2 sensor bypass
- Going green!
- what make is my klx 250
- Is my 2007 KLX250s making enough power with these mods...
- carb problems
- New Owner & Questions
- Aprilla SXV 550 with Klx250sf engine
- I have a two brothers Exhaust, looking to trade
- applying MCM and ACR removal
- Correct feed for KLX250SF wiring, cables, hoses??? (pics inside)
- Sonic disk lock
- Saddle bags
- Stuff on Ebay " Not my stuff"
- Sproket
- Fmf q4
- Two for One
- Jetting was fine until....
- Electrical issue.. darn.
- sit&fly seat cover for klx250s
- Making a block off plate
- Any differences between 2006 and 2007?
- Is it gone?
- Help Understanding KLX250s upgrades
- Rusting ..?
- This is What Happened This Morning...
- 351 Glowing Header - Lame!
- Alarm
- Fork stiction?
- To good to be true?
- EFI klx250s (D-tracker) ejk fitment
- There's Gremlins in my bike
- need help, my klx suddenly cannot start, no spark
- Barnett Clutch spring upgrade
- Got all minor mods done testing is over!!
- 2008 KLS250S starting issues
- Can't rev past 12000 rpm while in gear
- Air suction valve block plate
- Pics/Video from Moto-fest weekend - 2014
- Foot Pegs Footrest For Kawasaki KLX 300R 250 650
- Grass Hopper is back, with even more stopping power!
- What's the oil flow direction through the filter
- wanted: chain guard
- China shift levers... Beware
- Strange exhaust note at cruising speeds
- 32,200 miles and 2 very tough winters...
- Notchy shifting
- What Super Moto Tires have you got?
- Swingarm bearing holes damaged - replace swingarm?
- What's it Worth?
- Aussie supermoto wheels
- Rear turn signals
- Clutch Levers - Australia?!
- cdi prodlem
- DIY LED turn signals!
- Need help!!! webcams 101 or pumper carb
- Bike swallowed WHOLE
- Carb issues?
- Quick fuel screw question
- Race Tech Rear Spring Installation
- I'm baaaack...
- For Sale 2006 KLX 250S
- Front Wheel Growl???
- Shift lever doesn't return after downshift
- Fuel bowl screws
- 2010 KLX330 Supermotard for sale in Australia
- Custom or go upgrade
- Shock replacement
- Letting Go 331 Big Bore Kit
- Rear fenders for klx
- Add HP without adding noise ?
- Replacing headlamp - can I go 100/80 watt?
- Rad guards/Acerbis tank?
- Front Fork Guards
- Stalling Problem. Help?
- River Run with WR250r. (Action Cam Video)
- Trouble with Clutch on 1987 KLR250
- Will a '09 tank and wings fit on an '06? With '06 seat?
- Bluetooth Helmet - Made it Myself
- My klx vs crf250l
- Accelerator CVK Carb Install?
- Idaho Singletrack (Video)
- New Subframe
- DG R series slip on
- It's gone!
- To south america fi rider with bad fuel problems
- My stator's putting out 69 VAC. Is this a concern?
- DIY Cylinder Head and Valve refresh
- Bike wont fire
- Selling my '12 KLX250s - and giving about $2k of accessories with it!
- Night Ride
- New rider! Questions about my used KLX
- Front & Rear chain sliders
- klx250s efi auto choke problem
- Removing Air Suction Valve System: WHY???
- I'm going to de smog my junk.
- Hello....long time lurker
- Anyone have a KLX351 near Denver?
- Air Lid jetting adjustment.
- Very Scared! Rode purchased bike home with lean jetting, how screwed is it???
- Insulated air box gains 1 hp
- Melted Side Panel
- Would you let someone test drive your bike?
- KLX250SF no digital display/won't start
- Brand New Seat Concepts Complete Seat For Sale !!
- Is the KLX250S For Me??
- valves
- foot pegs
- Tiger 800XC Windshield on KLX250s. (Pics)
- Another Ride Report!
- Ride Report
